Remove Lift Kit
Old May 7, 2010 | 01:30 PM
arthurfelter's Avatar
arthurfelter
Remove Lift Kit
It seems that my question is a unique one; while everyone is lifting their trucks, I'm looking to take the 3" lift out of mine.
My research tells me I'll need the following: new u-bolts and blocks for the back, and for the front new track bars, springs, shocks, and I read somewhere on here something about bushings (but don't know which bushings...). And I assume that it'll need to be aligned when all is said and done?
Am I missing anything? Anything I should watch out for?
Old May 7, 2010 | 02:04 PM
Witty73's Avatar
Witty73
First of all, what year and model is it? Secondly, how is it lifted?
Old May 7, 2010 | 03:28 PM
ChaseTruck754's Avatar
ChaseTruck754
Also - how about 2 or 4wd.
Yes he says "track bars" and "springs" - but is he talking some panhard bar that may be on his 4wd, or the radius arms? Is it leaf spring or coil spring?
Old May 7, 2010 | 03:46 PM
muladesigns1's Avatar
muladesigns1
bushings may be the c bushings. most people dont change them with a 3" lift though. shocks, lift blocks out back? coils, or leafs up front.
a 3" is pretty mild, why are you removing it?
Old May 7, 2010 | 10:47 PM
arthurfelter
how is it lifted?
I assume you're asking if it's a suspension lift or a body lift? It's a suspension lift.
My truck is a 77 150, 4 wheel drive, coil springs in the front (with 2 shock absorbers on each side, if that makes a difference).
Ever since I was a kid I've loved the looks of these trucks, and always wanted one. This is my daily driver, and I don't plan on doing any off-roading, so having something the missus can get into easier is appealing.
Am I right that it will need to be aligned afterwards?
Old May 10, 2010 | 02:34 PM
ChaseTruck754
Based on the above your first post seems correct.
As for the bushings - see the post above yours.
If the bushings haven't been changed then you may not need an alignment but it wouldn't hurt I guess.
Old May 11, 2010 | 10:59 AM
bmarkline's Avatar
bmarkline
As far as the trac bar, most lift kits sold just have a dropdown bracket to utilize the factory bar, so you could just remove the extra drop bracket. And the rear you would just remove the lift blocks, you dont need new ones. Although new u-bolts then isnt a bad idea.
Old May 11, 2010 | 01:17 PM
jb10's Avatar
jb10
i have a 78 that i am working on and a 77 that i am using for parts.
i may be interested in buying the parts or possibly swapping with you.
Treacy
May 18, 2019 01:09 PM
Bigblackbastrd
May 9, 2017 08:54 PM
shameless
21
Feb 12, 2017 02:01 PM
V AZARIAH V
Offroad & 4x4
Sep 20, 2014 07:28 PM
strokin'_tatsch
25
Aug 18, 2010 11:47 AM
