I beam pivot bushings???
Hey guys. Finally at 317k miles i need to get off my butt and change out my I beam pivot bushings, tie rods, and tie rod ends and remember this is a 2WD. I have never changed the pivot bushings, but it looks straight forward. Has anyone done this that can confirm what needs to be done to change these bushings? It looks like you could just lift the truck, unbolt it, drop the beam down and change them out, but i could be missing something. Thanks guys!
I did it on my 250 4X4 gasser. It wasn't too bad. I ended up taking the whole front end out and working on it on the bench. The pivot bushings weren't too bad to take out, I think that I used a "C" frame press from harbor freight (like $30 I think) and pressed them out. Check to see if you need to save the metal "shield" from the old bushings. Energy Suspension said something about needing to use to old ones on some vehicles, although I didn't need them on mine. The tie rods shouldn't be too bad to do. Hope this helps.
Red
Red
So the bushings have to press out??? I was afraid of that actually, but i will go to Harbor Freight and see if i can find that press. I don't have any kind of press in my shop for this so i will have to buy one. the tie rods won't be bad, its just the pivot bushings i'm worried about. I don't want to have to pull the hole front end out of the truck. LoL.
What you can try to do is to take a drill and drill around in between the rubber and the metal rim and that should loosen up the rubber so it should fall out. Use like a 1/2" drill bit and it will "walk" around the rubber and separate from the steel, and then you should be able to punch the steel shell out if need be. You might be able to torch them out too, but that could get bad real quick, so I would do everything else first.
Red
Red
Yes, you have the rubber bushing and then there is a steel shell that goes inside the axle. I don't think that you'll need to save the steel. Look at your new bushings and check the o.d. and see if they will fit in the axle or if you need to save the steel pieces. What kind of bushings did you get?
Red
Red
Thanks, but I think we're talking about 2 different things. The 2wd trucks don't have a front axle, so our bushings are different.
Chris and Mike, I will try to get as many pics as i can remember to take if i do them this weekend. I will be picking up the parts tomorrow. Got MOOG poly bushings, tie rods, and ends. Once this is done then my front end will be like brand new except the shocks and springs. shocks will be coming soon. Hopefully it won't be too bad. This has been on my "to do's" for about the past year, but it's finally gotten to the point of the I Beams movings up and down while i'm driving causing a shimmy and the tires to wear out and wear really really weird. My front tires have around 25k miles on them and parts of the thread are almost gone while other parts look brand new. it's really strange. Hoping to get more info on this by the weekend so i at least almost know what i'm doing.
If someone has the OBS specs handy, post up the measurement from the top of the I-beam to the frame.
