F25= F250 2WD
Y= 360 cu in 2bbl V8 engine
R= San Jose Assy Plant
R05656= 1973 Sequential Serial Number
WB 133= 133" wheelbase
Color H= It doesn't show an "H" for '73 in the US. In Canada "H" is med. green metallic
Model F252=F250 2WD pickup 7500 gvw
Body 64= (6) light green and medium green vinyl (4) styleside pickup bed
Trans G= Automatic transmission
Axle 24= Dana 60 4.10 non-locking 5300 lb capacity
Max GVW 7500= 7500 lb Max GVW
DSO 74= Seattle District Sales Office
Ok, thanks! I had a hunch about a lot of that stuff, nice to know for sure. The truck was a nice shade of green, and I found some paperwork that says it's 'seapine green metallic.' Any ideas on what the paint mix for that would be?
I'd appreciate it if someone could decode my vin and door tag, here's the numbers:
F25YRR05656
WB: 133 Color: H Model F252 Body: 6 4 trans: G axle: 24 max GVW: 7500 lbs DSO: 74
thanks
Sam
V.I.N. tag
F25= 1973 F250 2WD
Y= 360 CID 5.9liter 2V carb
R= San Jose
R05656= consecutive unit number
W.B.= 133 inches
Color (H)= Dark brown met.
Model (F252)= 7,700 G.V.W. 133" wheel base
Body (6 4)= 6= ?? 4= styleside pick-up
Trans (G)= automatic
Axle (24)= Dana 60 4:10 ratio Capicity LBS. 5300
Max G.V.W.= 7500 LBS.
DSO (74)= Seattle
The only two I'm not sure of is: Color (H)= Dark brown met. and Body (6 4)= 6=?? 4= styleside pick-up, because I am using a 1977 Ford manual to decode this 1973 VIN tag and those two are questionable. Maybe someone else will chime in with the correct information for those two item's. The rest of the info should be correct though. -Ed
Even that site has a few missing items.
Case in point, color codes on dad's 74 are MN. One is correctly id'd as wimbledon white, while the other is skipped for 74.
The window sticker lists the colors as wimbledon white and ivy glow glamour metallic. Since dad bought it new, and I was 9 at the time, I can verify that color of green was indeed factory. It's an emerald green, with lots of metal flake in it. I think it was a 74 only color, though other years offered a very similar shade of green, just less metal flake.
Top if the passenger frame rail between the core support and firewall and again on the top passenger frame rail under the cab.
Josh
The VIN stamp under the hood generally tends to be near the motor mount towers. But, as said, can be just about anywhere between core support and firewall.
If that site doesn't work, it's best just to ask and Mike0o0o0o0o0 will give you the details
