Weiand Intake?
Old Apr 24, 2010 | 02:20 PM
art015's Avatar
art015
Weiand Intake?
Greetings!
Building a 460 for my F250 to pull my 8000# car trailer. Not a hot rod motor, I want something that will pull my trailer effortlessly at 70-75mph (3:55 gears/T18) and give 8-10 MPG.
What I have so far;
1973 passenger block/crank/rods
E6TE-DA heads
GM style HEI (Proform)
Flat top pistons
"Pulling" cam (comes with the engine kit).
I traded for a Weiand Stealth intake, #8012. Would this intake be beneficial in my application or should I re-use my cast iron one? Weiand says it makes power from idle to 6800, this engine will never get over 4000rpm, cruise around 2800rpm. I plan on using a 4100 Autolite carburetor.
Old Apr 24, 2010 | 07:10 PM
mark a.'s Avatar
mark a.
IMO the 8012 is the best dual plane manifold ever made for a 460. 373's would probably be a better gear for what you want to do.
Old Apr 24, 2010 | 07:51 PM
art015's Avatar
art015
Thanks!
I'm thinking of blocking the crossover heat and using an electric choke, would that make the thing too "cold natured"?
Old Apr 25, 2010 | 02:12 AM
tinaheels's Avatar
tinaheels
i would not block the crossover its not a good idea
Old Apr 25, 2010 | 09:42 AM
Bear 45/70's Avatar
Bear 45/70
Actually it is a good idea for two reasons.
First, the cooler the carb the better for power making, both torque and horsepower.
Second fuel economy will increase.
Down side is slower warm up, but with a tow vehicle, what's the rush, take an extra 5 minutes on start up to check the hitch, safety chains, wheel lug nuts, tire pressure and lights.
The only reason the crossover exists is to speed up warm up so impatient driver don't have to wait. You don't see a crossover on EFI systems because they compensate with timing and the fuel delivery.
Old Apr 26, 2010 | 11:01 AM
art015's Avatar
art015
Thanks, good info!!
Old Apr 27, 2010 | 11:48 AM
03HD05ZX6R's Avatar
03HD05ZX6R
The stealth has huge runners. It would be a terrible intake for your application.
Old Apr 28, 2010 | 08:44 AM
mark a.'s Avatar
mark a.
Do a little research, we are talking about the 8012. It's recomended from idle to 6800 rpm. It does not have "huge" runners.
Old Apr 28, 2010 | 09:43 AM
03HD05ZX6R's Avatar
03HD05ZX6R
I run the 8021 on my 466 with A429 heads, and yes the port at the head is larger than the 8012, but the two intakes are the same from roughly an inch back from the head to the carb flange. And compared to a stock intake, performer, or even the performer rpm, the stealth ports are HUGE. Dude said he doesn't want to run it past 4k, I'd run a performer. Never a stealth.
Old Apr 28, 2010 | 02:02 PM
mark a.'s Avatar
mark a.
It 55 mph mine isn't even turning 4000rpm and the improvement I got over the performer when I took off was like night and day. It comes out of the hole a lot stronger and I can tell a little better throttle response.
Old Apr 28, 2010 | 02:24 PM
jeremy2008's Avatar
jeremy2008
******** width="640" height="385"><param name="movie" value="http://www.youtube.com/v/lqqtK0lPjrA&hl=en_US&fs=1&color1=0x234900&color2=0 x4e9e00"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lqqtK0lPjrA&hl=en_US&fs=1&color1=0x234900&color2=0 x4e9e00" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed>*********>
Watch this see what u think. I know it is a 350 got it.
Old May 1, 2010 | 10:57 AM
mark a.'s Avatar
mark a.
Interesting, I always like watching this kind of stuff but it really doesn't apply to the 460 & the stated manifolds.
Old May 1, 2010 | 04:48 PM
jeremy2008's Avatar
jeremy2008
I know but just a idea of the set up of the manifolds thems selfs.
Old May 8, 2010 | 09:17 AM
cadunkle's Avatar
cadunkle
But still, completely irrelevant for a 460.
Old May 10, 2010 | 06:20 PM
mechanic58's Avatar
mechanic58
Good thread, this is exactly what I am intending to do. I just picked up an '85 E350 Club Wagon with a good running 460 in it and I have a nice set of C9VE heads to go on it. I am planning to pull this sorry-a$$ed 7.3 out of my F250 and put the 460 in it.
rockdawg84
Sep 15, 2012 03:12 PM
RabidJade
Oct 22, 2010 07:26 AM
mpuvdd
Aug 16, 2009 11:34 AM
76 F250 4X4
Dec 11, 2003 06:43 PM
chesid24
Feb 10, 2002 12:11 AM
