Torque Specs for mains and oil pump. I'm out in the garage
Main caps: 95-105
Oil Pump: 25
Oil pan: small bolts 7-9 large bolts at front/rear seal 9-11
Be sure to set your thrustbearing and measure crankshaft end play. It usually falls in spec but smoetimes is too tight and thrust bearing needs clearancing. Spec for end play is .004"-.010", .012" max.
Oil Pump: 25
halltm
04-13-2011 10:25 PM
390cobrajet
52
08-18-2007 11:45 PM
lvmoose007
12-05-2002 11:05 AM
