Side window mounting
Old Apr 17, 2010 | 11:59 PM
tip49's Avatar
tip49
Do the side mirrors sit exactly center in the base bracket or off center. I will be installing side mirrors tomorrow. I had to adjust my vent windows in the frames to ensure good seal with outer frame.
Did a bunch of little projects today, got emerg cable remounted, put some SS trim on hood; painted side mirror base brackets, etc
Mounted hood release assembly in hood front, but the release doesn't s seem to fit properly in the handle. I'll take pics tomorrw to ensure I have it right.
Later
Tom
Old Apr 18, 2010 | 12:23 AM
Julies Cool F1's Avatar
Julies Cool F1
Hi Tip!
I'm not sure I understand the question?????? But it's probably just me.
Let me at least bump this back up for you.
Old Apr 18, 2010 | 11:01 AM
tip49's Avatar
tip49
window fitment
Thanks Julie;
I think I answered my own question, the window lift channel is 19 1/8" long whle the glass is 20 5/8" long. I had one old window that I measured off of and it looks like the glass is centered in the lift channel.
Now; what is the tab or piece attached to the channel, what is its' function ?
Tom
Old Apr 19, 2010 | 10:58 AM
tip49's Avatar
tip49
Lift channel end tab
So......... anybody have even a guess as to what the functon is of the piece that is riveted to the side window lift channel ?
My guess is some sort of guide so keep the window in the rear window guide bracket ?
Old Apr 20, 2010 | 11:06 AM
tip49's Avatar
tip49
Old F1 are you out there?
Ray;
Can you put some clothes on sometime and check to see if your side window lift channels look anything like these ? I'm not sure of the orientation of the tab, is it front or back ?
Old Apr 20, 2010 | 11:13 AM
Old F1's Avatar
Old F1
[QUOTE=tip49;8792067]Ray; Can you put some clothes on sometime and check to see if your side window lift channels look anything like these ? I'm not sure of the orientation of the tab, is it front or back ?QUOTE]
I’m on to it boss, might be a hour or two, free help is not very dependable!................ Now, where are those clothes? !
Old Apr 20, 2010 | 12:39 PM
tip49's Avatar
tip49
Thanks
Take your time; don't want you to offend the neighbours. Hey can you check to see how thick the felt washers are; also I'm going to have to fab something up.
I'm on the road to work today, talke to you soon. What are you up to on your truck these days.
Tom
Old Apr 20, 2010 | 02:21 PM
Old F1's Avatar
Old F1
Originally Posted by tip49
Hey can you check to see how thick the felt washers are; What are you up to on your truck these days. Tom
Felt washers, …………………what felt washers?
Not much, tractor had a rear flat tire (ugly job), son wanted some mag wheels put on his ice cream truck, ……………….I’m just a happy pig rolling in the dirt.
Are you thinking about going to Red Deer swap meet, I might be getting a day pardon for a trip!
Tab goes to the front.
https://www.ford-trucks.com/forums/a...1&d=1271790861
Old Apr 20, 2010 | 02:47 PM
tip49's Avatar
tip49
Thanks !
What purpose does this tab have ? Thought the manual says felt washers go against glass, before retainer clips. I'll check manual again. I won't get to the truck for another week.
When is the Red Deer meet ?
I work until the 28th of April; home that evening.
Later
Tom
Old Apr 20, 2010 | 03:50 PM
Old F1's Avatar
Old F1
From what I could see, it looks like it slides up the window channel along with the glass kind of like a stabilizing guide feature.
Red Deer is Friday April 30 and Saturday May 1……..I think!
Old Apr 20, 2010 | 05:22 PM
Corner Gas's Avatar
Corner Gas
I just put a window in the passenger side of my truck and I didn't see any felt washers on either door. It went in real easy after I figured it out. lol
Old Apr 21, 2010 | 09:19 AM
tip49's Avatar
tip49
Thanks for the input
I may use some sort of washer between the glass and retainer, would make for a smoother operation.
hillcountryflt
Nov 3, 2014 11:00 AM
lustana
Mar 3, 2014 06:52 PM
FE352
Jul 22, 2009 12:12 PM
velcro7279
1966 - 1977 Early Broncos
Nov 1, 2006 01:50 PM
Craig67
1997 - 2003 F150
Mar 7, 2005 08:19 PM
