Do the side mirrors sit exactly center in the base bracket or off center. I will be installing side mirrors tomorrow. I had to adjust my vent windows in the frames to ensure good seal with outer frame.
Did a bunch of little projects today, got emerg cable remounted, put some SS trim on hood; painted side mirror base brackets, etc
Mounted hood release assembly in hood front, but the release doesn't s seem to fit properly in the handle. I'll take pics tomorrw to ensure I have it right.
I think I answered my own question, the window lift channel is 19 1/8" long whle the glass is 20 5/8" long. I had one old window that I measured off of and it looks like the glass is centered in the lift channel.
Now; what is the tab or piece attached to the channel, what is its' function ?
Can you put some clothes on sometime and check to see if your side window lift channels look anything like these ? I'm not sure of the orientation of the tab, is it front or back ?
[QUOTE=tip49;8792067]Ray; Can you put some clothes on sometime and check to see if your side window lift channels look anything like these ? I'm not sure of the orientation of the tab, is it front or back ?QUOTE]
I’m on to it boss, might be a hour or two, free help is not very dependable!................ Now, where are those clothes? !
Take your time; don't want you to offend the neighbours. Hey can you check to see how thick the felt washers are; also I'm going to have to fab something up.
I'm on the road to work today, talke to you soon. What are you up to on your truck these days.
Hey can you check to see how thick the felt washers are; What are you up to on your truck these days. Tom
Felt washers, …………………what felt washers?
Not much, tractor had a rear flat tire (ugly job), son wanted some mag wheels put on his ice cream truck, ……………….I’m just a happy pig rolling in the dirt.
Are you thinking about going to Red Deer swap meet, I might be getting a day pardon for a trip!
What purpose does this tab have ? Thought the manual says felt washers go against glass, before retainer clips. I'll check manual again. I won't get to the truck for another week.
When is the Red Deer meet ?
I work until the 28th of April; home that evening.
I just put a window in the passenger side of my truck and I didn't see any felt washers on either door. It went in real easy after I figured it out. lol
