Changing Bolt Patterns
Old Apr 16, 2010 | 10:21 PM
86bigred's Avatar
86bigred
i say re drill a new set of front rotors,that way you still retain those 11" rotors and get rear axles and drums from an f100 with the smaller bolt pattern.
Old Apr 16, 2010 | 10:38 PM
Rogue_Wulff's Avatar
Rogue_Wulff
One problem with using the rear axles/drums from an F100. F150 uses 11" drums, F100 uses 10" drums.
Old Apr 16, 2010 | 11:41 PM
Fordzilla80's Avatar
Fordzilla80
The reason that style isn't offered in 5x5 1/2 is because the wheel isn't meant for trucks.I say call them up and see if they can custom make a set of 5x5 1/2's for you.
Old Apr 17, 2010 | 06:10 AM
Blue80's Avatar
Blue80
I did, no go. Does anyone know if all 5x4.5 bolt patterns have the smaller brakes? I really don't want to downsize the brakes.
Old Apr 17, 2010 | 06:38 AM
Diesel_Brad's Avatar
Diesel_Brad
Again. Are those wheel rated to carry a 5ooo lb pickup? Proably not
Old Apr 17, 2010 | 07:50 AM
Chitownhillbilly's Avatar
Chitownhillbilly
Originally Posted by Blue80
Series 483 Black
It may be easier to re-drill what I have? Do all 5x4.5's have small brakes?
Why does it have to be this manufacture? Those Torq thrust style wheels are made by about a few different companies. American Racing has them in Gray, It would be a lot easier to just paint the wheels than change bolt patterns.
AR Wheels...
Old Apr 17, 2010 | 12:45 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Unfortunately, all 5x4.5 have the 10" power brakes.
5x5.5 have 11" brakes, either power or manual.
All F-100 vehicles 4600 and 4700 GVWR with 10" brakes and the 5x4.5 pattern came with power brakes. If they had manual brakes they had 5x5.5 pattern with 11" brakes.
F-100 vehicles with a GVWR of 5000, and all F-150, and E-150, U-150's came with 5x5.5 and 11" brakes, if they had power brakes or not.
Source Ford light truck service specifications: FPS 365-322-81
Old Apr 17, 2010 | 08:43 PM
Blue80's Avatar
Blue80
Diesel, I don't think my shortbed F100 is anywhere close to 5000lbs. More like the weight of of 70's mustang, but I may be wrong?
Thanks 81, that was exactly the info I was looking for.
Old Apr 18, 2010 | 02:44 PM
81-F-150-Explorer
I think he meant GVWR of 5000 lbs. That is the weight of the truck fully loaded or aproximately 2.5 tons. The truck itself weighs aproximately 1.5 to 2 tons depending on model and accessories.
Glad to help.
Old Apr 18, 2010 | 07:54 PM
Blue80's Avatar
Blue80
I appreciate everyone's insight. I hope I can find the wheels I want or something real similar in my bolt pattern. If not, I'll change the bolt pattern on what I have. Does anyone know the curb weight of a 80 shortbed F100? I'd just like to know.
Old Apr 18, 2010 | 08:08 PM
Greyf100's Avatar
Greyf100
my '81 f100 ranger std cab, long bed, 5 on 4.5" weighs 4000# with me in it unloaded.
im getting ready to swap to 5 on 5.5" brakes..
new spindles, rotors, pads, calipers, and wheels for the front
new axle housing, axle shafts (5.5" uses big bearing housing 4.5" uses small bearing housing), drums, shoes, and wheels for the rear.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
i know they arent the exact same, i love the torque thrusts also...
Old Apr 19, 2010 | 02:50 AM
truckerboy's Avatar
truckerboy
when i sold my short bed 81 F100 2x4, i got $280 at $.07/lb, so it was 4000 even. should be close to yours.
Old Apr 19, 2010 | 07:33 AM
  #28
Blue80's Avatar
Blue80
It seems like I read somewhere that it weighed 3700 lbs, but I can't find it anywhere.
Old Apr 19, 2010 | 01:29 PM
  #29
81-F-150-Explorer
4000 lbs equals 2 tons.
3700 lbs equals 1.8 tons aprox.
You can get a close aproximation by taking your maximum GVWR, and taking away, in your case 1/2 a ton from that to get a aproximate weight of your truck.
Example, 5000 LBS GVWR (2.5 ton), take away 1000 (1/2 ton), equals 4000, or 2 tons.
Example, 4700 LBS GVWR (2.35 tons) take away 1000 (1/2 ton) equals 3700, or 1.8 ton aproximate.
The only other way to get more accurate than that, is to have the truck weighed when it is empty.
(with a F-250) you want to take away 3/4 ton, and F-350 1 ton etc..)
Old Apr 21, 2010 | 12:53 AM
  #30
Sport45's Avatar
Sport45
He better weight it as you suggest. My F-250 has a GVWR of 8800 pounds and weighs 6000 empty. Of course subtracting GVWR from the nominal capacity should always give a heavy estimate. That's a good thing when specifying tires and wheels...
apachetech
Jan 4, 2015 04:11 PM
77_f250_custom
1997 - 2003 F150
Nov 29, 2014 10:42 AM
medicpg
Mar 31, 2008 12:52 PM
SoArkSI
Mar 22, 2006 10:50 PM
DT 466Man
1983 - 2012 Ranger & B-Series
Aug 15, 2003 01:54 PM
