i say re drill a new set of front rotors,that way you still retain those 11" rotors and get rear axles and drums from an f100 with the smaller bolt pattern.
The reason that style isn't offered in 5x5 1/2 is because the wheel isn't meant for trucks.I say call them up and see if they can custom make a set of 5x5 1/2's for you.
I did, no go. Does anyone know if all 5x4.5 bolt patterns have the smaller brakes? I really don't want to downsize the brakes.
It may be easier to re-drill what I have? Do all 5x4.5's have small brakes?
Why does it have to be this manufacture? Those Torq thrust style wheels are made by about a few different companies. American Racing has them in Gray, It would be a lot easier to just paint the wheels than change bolt patterns.
Unfortunately, all 5x4.5 have the 10" power brakes.
5x5.5 have 11" brakes, either power or manual.
All F-100 vehicles 4600 and 4700 GVWR with 10" brakes and the 5x4.5 pattern came with power brakes. If they had manual brakes they had 5x5.5 pattern with 11" brakes.
F-100 vehicles with a GVWR of 5000, and all F-150, and E-150, U-150's came with 5x5.5 and 11" brakes, if they had power brakes or not.
Source Ford light truck service specifications: FPS 365-322-81
Diesel, I don't think my shortbed F100 is anywhere close to 5000lbs. More like the weight of of 70's mustang, but I may be wrong?
I think he meant GVWR of 5000 lbs. That is the weight of the truck fully loaded or aproximately 2.5 tons. The truck itself weighs aproximately 1.5 to 2 tons depending on model and accessories.
Thanks 81, that was exactly the info I was looking for.
I appreciate everyone's insight. I hope I can find the wheels I want or something real similar in my bolt pattern. If not, I'll change the bolt pattern on what I have. Does anyone know the curb weight of a 80 shortbed F100? I'd just like to know.
You can get a close aproximation by taking your maximum GVWR, and taking away, in your case 1/2 a ton from that to get a aproximate weight of your truck.
Example, 5000 LBS GVWR (2.5 ton), take away 1000 (1/2 ton), equals 4000, or 2 tons.
Example, 4700 LBS GVWR (2.35 tons) take away 1000 (1/2 ton) equals 3700, or 1.8 ton aproximate.
The only other way to get more accurate than that, is to have the truck weighed when it is empty.
(with a F-250) you want to take away 3/4 ton, and F-350 1 ton etc..)
He better weight it as you suggest. My F-250 has a GVWR of 8800 pounds and weighs 6000 empty. Of course subtracting GVWR from the nominal capacity should always give a heavy estimate. That's a good thing when specifying tires and wheels...
