Max RPM
Old Apr 13, 2010 | 06:24 PM
jeddi03's Avatar
jeddi03
Max RPM
I have a 1977 F100 with a 302 and 3 speed manual transmission California emissions. The question I have is does my truck have a rev limiter, or does my truck just not rev that high? When I am 1st or 2nd I can only get to approx. 4600 - 4800 rpms before I have to shift. I just always thought that these engines could wind up a little more, but maybe not, that is why I am asking. Is my engine just not set up for high revs or is there another problem?
Thanks!!!
Old Apr 13, 2010 | 06:47 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
There is no rev-limiter. But it's a truck 302, not a Boss 302.......so it's gonna get really unhappy at around 5000 rpm.
Old Apr 13, 2010 | 06:56 PM
75F350's Avatar
75F350
Most stock cams, lifters, valve springs, heavy rotating assembly, and heads will not permit the engine to rev like a race engine.
Limiting flow numbers for the heads are also contributing factors.
Old Apr 13, 2010 | 07:50 PM
sdg0080's Avatar
sdg0080
not to mention its 30+ yrs old...lol
Old Apr 13, 2010 | 09:05 PM
Nathan Plemons's Avatar
Nathan Plemons
The 302 has the potential to spin quite high with it's large bore / short stroke configuration. As others have mentioned, however, it was built and put in a truck so it was never designed to rev terribly high.
Honestly I couldn't tell you how high mine revs because I've never really decided to push it that hard. Mine doesn't have a tach, but if I remember correctly I think I've seen 30 MPH in first gear, which by my math puts me around 3600 RPM's. I'm thinking I might have also pushed it to 90 MPH once, which would put me in the same RPM range.
Just not worth blowing it up. Now if I had some money for new heads, cam, rockers, headers, intake, etc, I have no doubt it could be made to turn 6000 easy.
Old Apr 13, 2010 | 09:47 PM
79FordBlake's Avatar
79FordBlake
I don't know how fast it was turnin cause I don't have a tach but the 302 in my 79 f150 with 3.00 gears ive had up to 120mph. Didn't sound like it was gonna fly apart or nothin. Its been warmed over a bit, bottom end is stock though. Trans has a shift kit. From a dead stop if you stomp on it won't shift outta first till 60mph. My dad built the engine in the truck. I been runnin it for 5 years. My dads been runnin it over 20 years before he gave it to me.
Iv'e had my completley stock 73 F100 302 with 3.25 gears and factory 2 barrel carb to 100mph.
Old Apr 14, 2010 | 07:31 AM
Nathan Plemons
If you know your tires sizes and tranny gear ratios (although for high speed you'd probably be in 1:1) I can tell you exactly what RPM you were turning for any given road speed. It's pretty simple math, I made a spreadsheet to do it for me years ago.
If you had 235/75/15's on it, that would have been 4190 RPM.
Iv'e had my completley stock 73 F100 302 with 3.25 gears and factory 2 barrel carb to 100mph..
With the same tire size as above that would be 3783 RPM.
Old Apr 14, 2010 | 07:56 AM
dkf's Avatar
dkf
I've had the stock 302 in my 74' up to 5500rpm already. Best to keep it well below 5k rpm. In stock form the 302 doesn't have a lot of HP so it will be slow to rev even with no load on the engine. When driving normally I shift before 3k rpm but my truck is light and I have steeper gears and the 4spd.
Old Apr 14, 2010 | 08:48 PM
79FordBlake
235/75/15's are what im runnin. Thats not to bad. But when I first floor it and 4barrel kicks on and it downshifts I bet that has her really turning until it shifts and comes back down. I don't do this all the time, maybe every couple weeks. Seems like I have to blow it out more often all the time with the quality of gas going down. I try to keep gas treatment in it at every fillup.
My 73 with stock engine seems to run good on almost anything.
Old Apr 15, 2010 | 07:44 AM
Nathan Plemons
Have you considered the possibility that maybe it's not tuned perfectly. Running a hair rich or a hair lean all the time and thus fouling the plugs just a little, then when you stomp on it and the secondaries open up it fixes your issue and it burns them off?
Old Apr 15, 2010 | 11:24 AM
79FordBlake
I feel like I have hijacked the thread from jeddi03, sorry for that. I have adjusted idle adjustments with a vac gauge. I need to adjust the float level though, it is a tad high. I started getting gas from the Shell station and the problem cleared up some. It didn't run worth a crap on the gas I had been gettin from the Walmart Marathon gas stations. My mom and dad's fuelinjected vehicles don't even run good on gas from there.
Old Apr 15, 2010 | 07:28 PM
Nathan Plemons
I prefer Chevron myself. The local Key Oil Company is alright. In general I'm not too picky except I will NOT get gas from Racetrack, or Swifty. My old car pinged on Racetrack gas and it was only 8.3:1 compression!
dogdude2003
Mar 5, 2005 04:45 PM
nokiadude
3.8 & 4.2L V6
21
Dec 8, 2004 10:00 PM
ksvtwin
1983 - 2012 Ranger & B-Series
Jan 21, 2004 07:20 AM
skunky396
Aug 15, 2003 12:22 PM
richard_d
34
Sep 19, 2001 05:00 PM
