high idle when cold
Old Jan 20, 2004 | 03:58 PM
ksvtwin's Avatar
ksvtwin
high idle when cold
i have a '95 ranger with 2.3L 4 cyl. When i first start the truck in the morning, it revs up real high, then goes back down to the usual fast idle. Then as it warms up, it drops to normal idle. THe truck runs great and I am not getting any trouble codes. Other than the initial high rev, it's fine. what could be causing this? I hate to rev a cold engine up that much. I don't have a tach but i'll bet its 1500 rpm or better. Does anyone have any suggestions? it only happens in the morning when it is completely cold. Thanks, Kent
Old Jan 20, 2004 | 04:22 PM
jfarmer's Avatar
jfarmer
My truck does the same thing and a couple of my friends have rangers to and they do it to, even the newer models. Im not sure if something is causing this or it is just the ranger itself. Im no expert by far so I cant really say.
Old Jan 20, 2004 | 06:36 PM
Dealford's Avatar
Dealford
My 97 2.3 winds up to 2200 rpm when it's around -15C. When it's around 0, it goes to about 1800 rpm.
Yours is behaving normally.
Old Jan 20, 2004 | 10:16 PM
B C fx4 Level II's Avatar
B C fx4 Level II
My 1990 Ranger 2.9L Did it, My wife's 97 Sable 3.0L Does it, and so does my 03 Ranger 4.0L. Perfectly normal.
Old Jan 21, 2004 | 07:20 AM
ksvtwin's Avatar
ksvtwin
Thanks, i was hoping it was normal. my full size ford doesn't do it so i wasn't sure if it was normal or not. it doesn't cause any problems, i just wanted to make sure it was running alright. thanks, kent
Peach Grower
Oct 4, 2011 05:16 PM
49willard
Apr 25, 2006 07:18 PM
ksvtwin
18
Dec 27, 2004 02:12 PM
ksvtwin
Oct 2, 2003 11:51 AM
