dumb q, jack rating?
Old Apr 9, 2010 | 03:05 AM
brooklyn's Avatar
brooklyn
...thinking about buying a shop jack which will work with my '78 F-150, auto, 4x4. I can use one rated for 2.5 tons, right? Just going one corner at a time w/ 6-ton jack stands? It doesn't need to be rated for the entire GVWR for any reason?
Old Apr 9, 2010 | 07:38 AM
BDawg171's Avatar
BDawg171
Your not lifting the whole weight of the truck so you would not need that kind of rating. I will say though that my 8400GVWR truck becomes hard to pump the corner even with a 3 ton. It does it, but certainly would not trust it for anything. It was a cheap HarborFreight aluminum full size one though. Even though it is rated for 3 ton it is so light weight that the pump itself is probably not of the highest quality. I have a feeling I could lift it with little effort on a 2 ton all steel quality jack.
Old Apr 9, 2010 | 03:52 PM
Richards73's Avatar
Richards73
i use a 2 ton all steel jack for my f250 it works fine
Old Apr 9, 2010 | 04:13 PM
sdg0080's Avatar
sdg0080
my 3 ton can get both rears off the ground long enough to get the stands under her. tho my 35"s make it interesting...
jasonodsky
Sep 21, 2016 09:33 PM
robles4242
Sep 30, 2010 03:15 PM
89F250_7.5
Aug 14, 2009 02:28 PM
Neil64
Nov 15, 2008 07:35 PM
J Hodges
Garage & Workshop
Jan 21, 2007 06:00 PM
