Jack Requirements
Old Nov 15, 2008 | 04:26 AM
Neil64's Avatar
Neil64
Jack Requirements
Hey Everyone,
I need to jack up front and rear the F250 PSD. Does anyone recall if I can get by with a one ton jack or will I destroy it. Also, what weight rating of jackstand should I look for when buying jack stands?
Thanks...
Neil
Old Nov 15, 2008 | 04:44 AM
ron's power stroke's Avatar
ron's power stroke
i use a 6 ton bottle jack..easy to use..easy to hide in the truck.... these front end are pretty heavy...makes a 2 ton jack hard to pump up..your truck wieght is around 7500.. i would find at least a 3000 lb stands..5000 would be better...
Old Nov 15, 2008 | 04:55 AM
UP_There's Avatar
UP_There
I use 3,000 lb jack stands, never had a problem. A one ton jack will probably not do the job. Like Ron I have a 6 ton bottle jack carried in the toolbox, also have a 3 ton, and a hi-lift jack. At home I use a 3 ton floor jack, always works like a charm
Old Nov 15, 2008 | 06:34 AM
That_Guy's Avatar
That_Guy
I have a 2ton and it barely lifts the front end, and you have to get it just right for it to work...
Old Nov 15, 2008 | 06:49 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I had a 2 ton floor jack that would lift and hold the front end up but it was straining. Now I have a 3.5 ton hi lift floor jack that lifts it much better and easier. I also use 3000 jack stands in addition to the jack, I am not just going to trust a jack if I am going to work on the front of the beast and mine is just a 2x4!
Old Nov 15, 2008 | 08:25 AM
Neil64's Avatar
Neil64
Wow
Thanks guys. I am glad I asked. I imagine a 3 ton or bigger floor jack is pretty large, huh?
Do all jack stands have their rated capacity on them?
Thanks..
Neil
Old Nov 15, 2008 | 08:32 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
They should have the ratings on them. Here's a few:
http://www.northerntool.com/webapp/w...atchallpartial
Old Nov 15, 2008 | 10:56 AM
rbaker6336's Avatar
rbaker6336
Originally Posted by RedBoat
I had a 2 ton floor jack that would lift and hold the front end up but it was straining. !
that depends on the jack
I have a 2 ton that will easily lift either ed of my truck and another that is only good for my lawn tractor
Old Nov 15, 2008 | 12:01 PM
Futuresweets-10's Avatar
Futuresweets-10
One thing people arent aware of.... I bought some 7k stands from harbor freight, but on the box it says that is 3.5k per stand. When you take the harbor freight sticker off the stand is labled 3.5k. They rate them by the pair so they can put a higher number
Old Nov 15, 2008 | 01:39 PM
rbaker6336's Avatar
rbaker6336
most stands are rated per pair,I have a 12 ton set of black hawk,which is 6t per stand
Old Nov 15, 2008 | 03:51 PM
guzzle92's Avatar
guzzle92
If you have a local Harbor Freight, check them out. They have pretty good prices on HD jack stands and jacks. I would not suggest that they be used in daily operation of a professional mechanic shop, but they do well for most of us shade trees.
Old Nov 15, 2008 | 07:35 PM
Neil64's Avatar
Neil64
I need to check mine
I have some HD jackstands at my parents house and I have used them on my Bronco but never on a F250 or heavier. I need to check out their weight rating. They are pretty old so....
I also have an old HD floor jack in a shed over there that I think can hold the weight of my F250. I need to check that out too buy I can't get it to the house due to all of the rain we have had. There is no way I can drag that thing through the mud.
So the only thing I have if the OEM jack and a 1.5 ton floor jack until the yard dries out.
I guess my plans will have to wait until it gets too cold to work outside....LOL....
Thanks...
Neil
No704
New Member Introductions
Dec 16, 2015 12:24 PM
nwatkins176
May 20, 2014 10:55 PM
Neil_E.
Large Truck
23
May 22, 2011 11:42 AM
Neil_E.
Nov 6, 2009 01:40 PM
neilf600
May 6, 2005 07:44 PM
