Headlight pull knob
Old Apr 2, 2010 | 12:20 PM
Rusty924x4's Avatar
Rusty924x4
Headlight pull ****
92 f150 4x4 5-speed 158,000 miles. My dash lights went out on me last night. I could turn the **** and it would work for a little while. But with my dash lights out it make my tag light, tail lights and front marker lights not work. I am thinking that the dimmer switch in the headlight pull **** has something to do with this. I can now turn my headlight pull **** around left to right and dash light not working. I did check my fuses. I replaced on 15 fuse that was blown. I could move the pull **** left and right and make the tail lights working. Anyone ever have the problem and can you tell me how to fix this. Thanks
Old Apr 2, 2010 | 12:28 PM
ExtrmZ's Avatar
ExtrmZ
my problem isnt the same, but also weird. my switch is broken, and when you pull the **** all the way out you get only headlights, then push it back in just a bit, and the rest come on. i would try to find a cheap switch out of a junk truck
Old Apr 2, 2010 | 12:47 PM
jas88's Avatar
jas88
I think the fuse for your taillights is blown. I am talking to both of you on this. The power for the instrument lights comes off the taillight fuse, then it has a 5 amp fuse of it's own.
I had this happen to me when I was bringing a trailer that my FIL gave me home from Arkansas. The wiring on the trailer was faulty and blew my tailight fuse. I could press the **** in a little bit and it would then make the lights work. I thought my switch was bad, too, but it was the fuse.
Old Apr 2, 2010 | 12:52 PM
nstueve's Avatar
nstueve
to add to jas88 you might want to crawl under your trucks this weekend and see if you can find a dead short where your power wire has grounded to the body... this can cause the fuse to blow just like faulty trailer wiring. Also check the rear trailer pig tail/plug. Sometimes these trucks get rewired from owner to owner depending on what they need it for and wires can be left dangling or not covered... had 2 trucks with this problem thus far myself...
Old Apr 3, 2010 | 02:53 AM
kell104's Avatar
kell104
I would replace your switch for sure. However when you unplug the harness from the switch check for burnt connections. These trucks seem to have a reoccuring problem with overheating the harness and burning off the connection to the switch.
Mine did it twice and the second time I installed a relay under the hood to supply power to all the exterior running lights and trailer lights directly from the battery rather than pulling all those amps thru the switch and I haven't had any problems since. Especially handy pulling campers that tend to have tons of running lights plastered over all sides.
92 Black Nite
Electrical Systems/Wiring
241
Jan 27, 2023 06:16 PM
The Terrible Blob
13
Feb 20, 2014 10:56 PM
92 Black Nite
Jan 25, 2010 10:05 AM
dhobdey1
Nov 28, 2009 08:39 AM
bebad96
Oct 14, 2005 03:16 PM
