Headlight switch pulled off
Old Nov 27, 2009 | 08:22 AM
dhobdey1's Avatar
dhobdey1
Help! I seemed to have pulled too hard on the headlight switch in my 1976 f250 4x4. The only way to turn on the lights is to pull the loose fitting **** off, then pull out on the stem, then put the **** back on, How can I tighten the **** back onto the stem? Thanks, Dan
Old Nov 27, 2009 | 08:27 AM
kadrocker's Avatar
kadrocker
you might have to super glue it back on
Old Nov 27, 2009 | 09:11 AM
alex211's Avatar
alex211
Glue it back on or go to the junk yard and get another ****, that kind of stuff is free at my local yard anyways. To remove the **** you have to first remove the dash bezel part way, Then pull out on the switch until the headlights come on. There is a button on top of the switch you have to press, press the button and the **** pulls right out of the switch.
Old Nov 27, 2009 | 10:16 AM
ranger429's Avatar
ranger429
You don't need to remove the bezel, stick your arm up from under the dash and then you can reach the button. No need to undo anything.
Old Nov 27, 2009 | 10:52 AM
alex211's Avatar
alex211
Never tried it that way, but most of the time that I remove the **** its when I'm removing dash parts.
Old Nov 27, 2009 | 12:26 PM
Fordworth's Avatar
Fordworth
Not only that but you can't get the dash off until the **** and stem are removed.
Old Nov 27, 2009 | 03:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The headlamp switches **** was only sold with the shaft, it was not available separately.
When the button is pressed on the headlamp switch, the **** & shaft come off as a one piece assembly.
D4FZ11661A .. Headlamp Switch Shaft & **** Assembly / Obsolete
Fits: 1975 F100/350 from serial number V80,001 & 1976/79 F100/350.
Fits: 1974/80 Pinto/Bobcat // 1978/79 Bronco.
MATLOCK FORD-MERCURY in Franklin IN has ONE = 800-987-3673.
COLE MOTOR CO. in Ada OH has ONE.
TED GREEN FORD in Stockbridge VT has ONE = 802-234-5301.
CARPENTER OBSOLETE PARTS in Concord NC has 15 = 714-786-8139.
D3TZ11661A .. Headlamp Switch **** & Shaft Assy / Obsolete
Fits: 1973/74 F100/350 & 1975 F100/350 before serial number V80,001.
LINCOLN OLD PARTS STORE in Clearwater FL has ONE = 727-445-1091.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
CARPENTER OBSOLETE PARTS has 15.
DON SANDERSON FORD in Glendale AZ has 25 = 623-842-8762.
Old Nov 27, 2009 | 04:25 PM
montana_highboy's Avatar
montana_highboy
Just go to the junkyard and grab you one, press this button to release the shaft and ****.
Old Nov 28, 2009 | 08:39 AM
dhobdey1's Avatar
dhobdey1
Thanks to all that responded, I didn't know the stem was supposed to come off with the ****, DUH, You learn something new every day, Thanks again!
62ESQ
1961 - 1963 F100 Unibody
Oct 11, 2013 01:59 PM
EastTexasTruck
18
Feb 24, 2009 12:11 AM
Shadowrider123
Oct 4, 2007 07:34 AM
MintFord
Dec 23, 2006 07:57 PM
tmwindham
1978 - 1996 Big Bronco
Oct 24, 2004 12:10 AM
