Head Light Switch Problem ... Maybe?
Old Oct 13, 2005 | 01:46 AM
bebad96's Avatar
bebad96
Exclamation Head Light Switch Problem ... Maybe?
Ok... I've got a problem ... I have no Dash lights or tail lights or marker lights when my head lights are on.
The funny thing is I can pull the head light switch **** out and after it hits the first click, I can slowly pull the **** out more and the dash lights and tail lights and marker lights will come on. But when I pull the **** fully out to turn the head lights on, the rest of the light go out except for the headlights.
Now I just recently replaced the head light switch thinking that would fix the problem, but it didn't.
So I would like to get this problem fixed asap... Got pulled over by the cops tonight on my way home ... but luckly got away with a warning when I showed them the problem with my truck... But on the bright side I did get a compliment on my dash lights from one of the cops.
So, any tips on how to fix this problem would be very helpful. Could it be possible that I got a bad "new" headlight switch from the part store?
Old Oct 13, 2005 | 07:31 AM
frederic's Avatar
frederic
Yes, it's possible (though unlikely) that you got a bad switch.
More than likely, the connector on the switch isn't fitting well, or the spades inside the connector are worn. I have this problem with my 93 crewcab, if I hit a pothole the dashlights may go on, or off, at will. A good bang on the dash fixes it temporarily, until the next pothole.
When I took the connector off the headlight switch, I was able to see that one female spade was expanded more than the others... so I worked it out of the plastic shell, squeezed it slightly, and put it back in.
No more dash light flickering. Zero. None. Might not be what is wrong with yours...
Old Oct 13, 2005 | 02:10 PM
bebad96's Avatar
bebad96
Thanks for the response...I'm gonna tear into the dash again and look at the switch. I'll post what I find.
Old Oct 13, 2005 | 02:24 PM
Popa Tim's Avatar
Popa Tim
hehehe, i was going to add that you did turn the **** counter-clockwise to make sure the dash lights aren't really just dimmed....
Old Oct 13, 2005 | 03:22 PM
bebad96's Avatar
bebad96
haha... yeah I did :P
anyways... Got the dash torn apart and got to the switch. Everything looks fine and it connects nice and snug. But I also noticed when I pull the **** out, I hear this clicking sound in the middle of the dash when I turn the headlights on. It sounds like it's coming from right above the selector for the heater. Any clue to what that is? Or could that be the problem?
Old Oct 14, 2005 | 03:16 PM
bebad96's Avatar
bebad96
Ok found the problem....it turns out it was a stupid fuse. Gah...anyways...thanks for the help.
92 Black Nite
Electrical Systems/Wiring
241
Jan 27, 2023 06:16 PM
csonni
40
Jun 21, 2020 06:42 PM
steuspeed
Jul 29, 2016 04:12 PM
Bob_91SC4x4
Oct 11, 2015 10:28 PM
The Terrible Blob
13
Feb 20, 2014 10:56 PM
