Fuel Pressure Issue
Old Mar 24, 2010 | 05:14 PM
DemonRace6's Avatar
DemonRace6
Hi!
Originally Posted by aklim
If I were do do an amp draw, I'd start from the pump back. Bad fuel pump means you change it. Since it is outside, at least in a diesel, it might not be an issue
100 Amp 6 Volt/12 Volt Battery Load Tester
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Would this work?
Old Mar 24, 2010 | 05:19 PM
DemonRace6's Avatar
DemonRace6
Hi!
Originally Posted by Izzy351
You can plumb a gauge into the bowl temporarily and run it to where you can see it while driving. Just revving it doesn't put it under load (unless you're on a dyno). You need to drive it. BTW, I may have missed it, but what's it dropping to?
So I just need a gauge before the bowl, no regulator?
WOT from 0 to 60
Regulator set to 60psi:
My diesel w/ Walbro pump drops to 0 psi
My grease w/ FASS HPFP pump drops to about 25 psi
Regulator set to 80psi:
My diesel w/ Walbro pump drops to 5-10 psi
My grease w/ FASS HPFP pump drops to about 35-40 psi
Old Mar 24, 2010 | 05:23 PM
DemonRace6's Avatar
DemonRace6
Hi!
I originally though it was a problem with my regulator and tested by clamping my return line to see if the pressure went up, and it did, but I sent the regulator back to Automotive and they replaced parts of it but when reinstalled I still have the same problem.
Here is a video of the test:
YouTube - 10-02-21 Regulator Problem 008.AVI
Old Mar 25, 2010 | 07:19 AM
Izzy351's Avatar
Izzy351
WOT from 0 to 60
Be careful -- you're starving the injectors big time!
There are two ports on the bowl -- one is after the filter (bottom passenger side where the lines go to the heads -- that's where I have mine plumbed in right now). The other is upper driver side, which is before the filter. That one will tell you if your pump is working or restricted somehow. If there's a restriction in the bowl, you'll know it right away. Leave the regulator set to where you normally run it. Mine is set to 60-65psi.
Old Mar 30, 2010 | 10:16 AM
DemonRace6's Avatar
DemonRace6
Hi!
I just found this thread: https://www.ford-trucks.com/forums/9...wl-delete.html
I think I might do this as I have wanted to delete the fuel bowl for a while now anyway.
With this done I will know if it is my fuel pump for sure or not. and I don't have to buy a gauge
Old Mar 30, 2010 | 11:01 AM
aklim's Avatar
aklim
Other than having more Real Estate there, is there a reason? Just curious. I live in an area with Winter so having the fuel bowl will be nice. Also, IIRC, until you get to 600HP or is it 500HP, the fuel bowl isn't a restriction.
How will you know for sure without a gauge? How will you set the fuel pressure WITHOUT a gauge?
Old Mar 30, 2010 | 11:28 AM
DemonRace6's Avatar
DemonRace6
Hi!
I want to remove it because I run the veg oil and going through this additional filter is expensive. Also I think the bowl might be the problem because I cleaned it and then this problem started. (but i had this problem with the extremely dirty bowl too)
I have the automotive regulator which sets my pressure, just no gauge before the fuel bowl
davidstereo
Sep 27, 2014 05:23 PM
johnarahill
23
Jun 30, 2013 06:24 PM
MONAVIERONJON
Jun 19, 2013 09:26 AM
Whitey Ford
Mar 16, 2010 04:59 AM
cef2lion
Apr 24, 2006 10:05 PM
