Fuel Pressure Issue
Old Mar 24, 2010 | 01:13 PM
DemonRace6's Avatar
DemonRace6
Hi!
Fuel Pressure Issue
I run WVO and got a lot of debris in my fuel bowl, so the fuel pressure was dropping.
Cleaned it out, replaced the fuel filter, but my pressure did not change. If i messed up the fuel bowl, or there is still debris in there that I missed, what is the best way to check it?
Old Mar 24, 2010 | 01:15 PM
aklim's Avatar
aklim
Could it be that the debris has your pump FUBARed?
Old Mar 24, 2010 | 01:42 PM
DemonRace6's Avatar
DemonRace6
Hi!
FUBARed?? I have separate pumps for the WVO system and my diesel system so no debris should have gone through my pump, but I am willing to check anything.
Old Mar 24, 2010 | 01:45 PM
aklim's Avatar
aklim
I know in Mercedes cars, they check the amp draw of the pumps. Can you do that?
Old Mar 24, 2010 | 01:52 PM
DemonRace6's Avatar
DemonRace6
Hi!
I'm not sure, that would make sense that its the problem though due to other factors.
How can I check amp draw?
Old Mar 24, 2010 | 01:59 PM
DemonRace6's Avatar
DemonRace6
Hi!
Checking Amp Draw with a Multimeter...
The last post here sums it up, if I understand it correctly. I can buy this meeter, clamp it onto the terminals on my pump with out removing anything. Start my truck, see amp draw at idle, rev it up, and see amp draw at high RPM when the pressure drops.
Good idea, Bad idea??
Old Mar 24, 2010 | 02:03 PM
aklim's Avatar
aklim
Replacing Your Fuel Pump - Popular Mechanics
connect an ampmeter in series between the power source and the device
ex. remove the power + wire and fit the ampmeter between the + wire and the device
alternitively you can get clamp on ampmeters they are dearer but you can test amps with out removing any wires they just clamp on over the wire and give you an amp reading
Old Mar 24, 2010 | 02:47 PM
Izzy351's Avatar
Izzy351
Where are you measuring the fuel pressure?
Old Mar 24, 2010 | 03:33 PM
DemonRace6's Avatar
DemonRace6
Hi!
On the return line
Old Mar 24, 2010 | 03:34 PM
DemonRace6's Avatar
DemonRace6
Hi!
OK, what should I be looking for? I know there is a 20 amp fuse for the fuel pump so I should expect it to pull less amps? More amps? And what is the solution, bad fuel pump?
Old Mar 24, 2010 | 03:36 PM
aklim's Avatar
aklim
If I were do do an amp draw, I'd start from the pump back. Bad fuel pump means you change it. Since it is outside, at least in a diesel, it might not be an issue
Old Mar 24, 2010 | 04:18 PM
01 EXCURSION MORRIS's Avatar
01 EXCURSION MORRIS
SUBSCRIBING
Old Mar 24, 2010 | 05:00 PM
Izzy351's Avatar
Izzy351
On the return line
You need to check the pressure at the bowl (pre-filter) under load to see if it's a pump issue or something jammed up in the bowl. hhmmm... That sounds bad. LOL
Old Mar 24, 2010 | 05:10 PM
DemonRace6's Avatar
DemonRace6
Hi!
I dont have another fuel pressure regulator though, how would I do this? Under load meaning the regulator set at 60psi (for example) or load meaning revving up to 2800 rpm?
Old Mar 24, 2010 | 05:13 PM
Izzy351's Avatar
Izzy351
You can plumb a gauge into the bowl temporarily and run it to where you can see it while driving. Just revving it doesn't put it under load (unless you're on a dyno). You need to drive it. BTW, I may have missed it, but what's it dropping to?
