Hutch mod fuel filter?
Just completed the hutch and harpoon mod on my tank, what in line filter is everyone using? I'm having a hard time finding a RACOR with a metal bowl, I don't really want a plastic one, as it invites problems if it gets hit by a rock or some other debris. I have a small cheap inline one on for the time being until I find the right one to bolt up under the frame....
on
Dahl 100 fuel filter / water separator. It's big, but mounts right up under the truck with lag bolts. I have a stock height 4x2, and even though it looks "dangerously low," it hasn't had a single problem with getting hit by anything. Far superior filtration and water separation, I even use a 2 micron full flow filter in it. Makes my fuel bowl Racor 10 micron filter almost useless.
I have done the fuel tank mods on other trucks using the various kits others have bought, so I decided to build up my own kit and put a spin on it with rigid tubing and stainless fittings
Ken, where did you get the SS 3/8 tubing and fittings ? I have installed a Strickly Diesel Hutch kit and it came with the Baldwin BF1212 filter and the FB1311 filter head. But I don't like the stock fuel pump location and I want to move it back to right in front of the filter. Right now I have the pre filter about 4ft from the pick up and it is about 2 1/2 ft from pump (stock location). So that is making me rethink the placement of pre filter and fuel pump. The reason I put the pre filter 4ft from pick up and just behind tail shaft of trans is if I hit or ran over something it would be less app to come in contact with it. But I am rethink that thought too. So my question to you where did you get the tubing and where were you going to place the pre filter and pump ? Thanks
I picked up the 3/8" SS tubing and the fittings from Grainger. I went to my local Parker store to buy everything, but they did not stock 5/16" SS tubing. I ended upi going on Graingers site and found everything on there available. I get a disscount through them too, so it was just as cheap. If you have a hydraulic supply store near you, they should be able to get the tubing for you.
Good eye! Yes, I am going to replace all the tubing from the tank to the pump with rigid stainless steel 3/8" tubing. I will use a small section of braided flex hose at the tank and at the pump, everything else will be bent up to fit. I plan on mounting the filter behind the transfer case near my oil by-pass filter.
Good thing you you have those rubber hangers, the fuel pump is going to make that tube humm..
