Fuel Filter Setup Differences?
Old Mar 23, 2010 | 08:00 AM
banjopicker66's Avatar
banjopicker66
The fuel filter housing on my donor '89 7.3 is cracked, but I found a replacement from an early '90's 7.3 - at least I think it was an early '90s, and I think it was a 7.3.
The '89 filter has a cast aluminum base with what looks to be a fuel return line, but the '90s one only has a thumb screw drain fitting as part of the filter housing.
Can I use the later one and just plug the return line?
I know Starmilt said that one was cheaper than the other.
Thanks for any insight!
Old Mar 23, 2010 | 09:17 AM
starmilt's Avatar
starmilt
They are all the same after 87 as far as I know, however you can get a different filter with a thumb screw on the bottom and delete the aluminum bottom piece.
starmilt
Nov 24, 2010 04:15 PM
starmilt
Jan 26, 2010 08:56 PM
whitey1
Oct 13, 2008 12:25 AM
lartross
Nov 30, 2006 01:54 AM
rhino3
Nov 13, 2003 05:53 AM
