hand primer pumps
Old Nov 22, 2010 | 10:15 PM
starmilt's Avatar
starmilt
hand primer pumps
There has been several inquiries over the years about hand pumps, with not a lot available. A friend of mine has an extra filter mounted right next to the stock one on his 6.9 and there is a primer pump mounted right on the filter header. This is aftermarket but looks like a stock setup. The primer lookes like one on a cat od john deere. The next time I am over there and think about it I will get the part #s for this setup.
Old Nov 23, 2010 | 12:59 AM
ytlogger's Avatar
ytlogger
I put a Racor water seperator with built-in primer in the suction side of my fuel system. Works great.
Old Nov 24, 2010 | 02:39 PM
kenpobuck's Avatar
kenpobuck
I was told that the old IH buses had hand primers on them as well. Don't know if they could be fitted up to our rigs tho.
Old Nov 24, 2010 | 04:01 PM
drewdole's Avatar
drewdole
id like to c a good pic off the set up. u just never no when u can clog a fuel filter. didn t u show a primer bulb from a outboard motor set up once. 392. ooo miles 93 f250
Old Nov 24, 2010 | 04:15 PM
catfish101's Avatar
catfish101
You can find filter heads with them built and plumb them up..Actually the simple way to do this is to put a hand primer bulb in your pick up line..Like one on a boat just like Bobcat does on their machines. Works fine.
avf100
Aug 14, 2013 05:25 PM
nixon_ca
Paint & Bodywork
Oct 27, 2004 12:50 AM
jamesdraughn
Paint & Bodywork
Oct 28, 2003 10:04 PM
cid
Paint & Bodywork
Feb 9, 2003 07:45 PM
