Valves
Old Jan 26, 2010 | 01:18 AM
starmilt's Avatar
starmilt
Valves
I know some 7.3 engines have upgraded valves.
Does all 7.3 have the better valves or just the factory turbo valves.
And the same question about the oil coolers.
Old Jan 26, 2010 | 11:31 AM
starmilt's Avatar
starmilt
Anybody know, I don't want to keep this block but do want to keep anything that will upgrade a 6.9.
Old Jan 26, 2010 | 11:40 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Turbo exhaust valves were inconnel.
Stock 7.3 NA valves the same as the 6.9 valves as far as metal composition.
Old Jan 26, 2010 | 11:42 AM
starmilt's Avatar
starmilt
Thanks Dave that was what I needed. Is the oil cooler upgrade only for the turboed motors too.
Old Jan 26, 2010 | 04:11 PM
9473's Avatar
9473
What I have shows the oil cooler bundle upgraded for the turbo, 30 fins/in vs 24 fins/in for the NA.
[IMG]file:///C:/Users/Owner/AppData/Local/Temp/moz-screenshot-5.png[/IMG]
[IMG]file:///C:/Users/Owner/AppData/Local/Temp/moz-screenshot-3.png[/IMG]
[IMG]file:///C:/Users/Owner/AppData/Local/Temp/moz-screenshot-4.png[/IMG]
Old Jan 26, 2010 | 08:56 PM
Dave Sponaugle
Basic changes between the 7.3 NA IDI and 7.3 turbo.
NA has 1" wrist pins
Turbo has 1.3125" wrist pins
The NA oil cooler 24 fins per inch
Turbo oil cooler 30 fins per inch
Turbo pistons were anodized on the crown.
Valves already covered.
You could use all the turbo parts on a NA 7.3, if you could find the connecting rods.
In a 6.9 you can use the 7.3 turbo oil cooler and exhaust valves.
Also the 7.3 style rockers is another 6.9 upgrade.
After running my engine, the turbo wrist pins are just more rotating weight.
And if you watch the pyrometer, the anodized pistons are not needed, they would just add more cost.
Ford probably used them since pyrometers were not stock equipment, that helped protect the pistons with the mild boost pressures and fuel settings that the stock turbo engines used.
ZRT 1000
Nov 19, 2019 10:02 AM
coolhand1994
Mar 27, 2009 08:16 PM
CowboyFromHell
Jul 16, 2008 05:52 AM
BUZZer67
Sep 13, 2006 07:22 AM
