IPR valve removal
Old Mar 17, 2010 | 01:53 PM
embry1123's Avatar
embry1123
IPR valve removal
Does an O2 sensor socket fit the IPR valve for removal or is it a must to get the Ford tool?
Old Mar 17, 2010 | 04:15 PM
bismic's Avatar
bismic
I bought the socket fairly cheap. I can not recall where right now. I will find it and post it.
Are you serious about changing it out? If so, I could ship you my socket and you could return it when you are finished w/ it. I would just need you to cover my shipping cost.
Old Mar 17, 2010 | 04:25 PM
embry1123's Avatar
embry1123
Mark, I certainly appreciate that. I will wait on that decision for now as my Autoenginuity will be here next Monday. I'm just trying to go through in my mind what I might be facing (to the lesser side of replacing the HPOP) My thoughts are that it (the IPR) could be defective, I saw that it's default position is "open" which wouldn't let the HPOP build any pressure. Also considering the possibilities of a potentially bad CMP or crank position sensor. Just can't seem to get my mind wrapped around the BIG pump going out so abruptly. Could also be injectors I suppose.
Old Mar 17, 2010 | 07:20 PM
04F-250mark's Avatar
04F-250mark
If I'm not mistaken it is a 1 1/16". Yall are talking about the on on the pasenger side Valve cover correct?
Old Mar 17, 2010 | 07:45 PM
embry1123's Avatar
embry1123
No, this is an early 03, it's on the back of the block. I wish it was on the valve cover!
Edogsf350
Apr 4, 2015 04:09 PM
jerkypants
Feb 20, 2012 08:50 PM
BobbyB
Jan 12, 2011 01:24 AM
embry1123
Mar 17, 2010 03:32 PM
peddleradv
Jan 16, 2009 09:25 AM
