6.0 help
Old Mar 17, 2010 | 06:53 PM
trick26's Avatar
trick26
6.0 help
Guys I don't post much but need help and advice. I have a 2004 f350 6.0 60,000 miles. I run the predator module and am putting out 430 hp. My question is this. I have never had head gasket problems never lost any anifreeze. Do I need to consider doing them with the arp studs? and what is the opinion on the egr delete is it necessary? If so does anyone know a very reputable shop near me. I'm 35 miles east of St. Louis, Mo in Illinois are some in southern Illinois here or Missouri close. I want the best. what is the best egr delete kit. And who makes the best guage pod with good guages.
thanks in advance for any help.
Mike
Old Mar 17, 2010 | 06:58 PM
vloney's Avatar
vloney
I'm in central Missouri. 161 mile marker on I44.
Old Mar 17, 2010 | 07:03 PM
bismic's Avatar
bismic
If you get Vloney to do the "head stud / egr system delete", it will be done right for sure.
Old Mar 17, 2010 | 07:04 PM
trick26's Avatar
trick26
whats your opinion can you do this for me and roundabout cost
Old Mar 17, 2010 | 07:11 PM
vloney's Avatar
vloney
I'm a dealer tech. If you want it done, I'll do it. As far as cost, I dont deal with money. Its roughly $100 per hour. Admins, delete if its not appropriate.........573-336-2000 for more information.
Old Mar 17, 2010 | 07:16 PM
trick26's Avatar
trick26
is the work I'm asking necessary or not there has not been any problems is the egr delete and the head gasket replacement needed thats what I need to know. Or do I wait till it pukes antifreeze.
Old Mar 17, 2010 | 07:19 PM
lakewood's Avatar
lakewood
It will save you money and hassle if you do it before it goes bad, and doing it before the EGR and gaskets take a crap will make it have a better chance of never happing.
Old Mar 17, 2010 | 07:35 PM
trick26's Avatar
trick26
the other day and a while back the truck started to run rough and wouldn't pull itself with white smoke whats this
Old Mar 17, 2010 | 07:45 PM
vloney's Avatar
vloney
My personal thoughts are that the egr delete is unnecessary, with the programmer, the headstuds would be insurance. I would also recommend a coolant filter for preserving the oil/egr coolers.
