Longer Speedometer Cable needed
Old Mar 17, 2010 | 07:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ongoingshow
Ok the truck that I have has a 351M and it had a T18 manual with 4x4 and now it has the same 351M but it has an E4OD bolted to it and the transfer case that was on the
E4OD is also under there. I would only need like 4" for it to be long enough but that just doesn't cut it. It's a 1978 single cab long bed with a 4" lift on it.
1973/78 F100/250 4WD T18: 78 7/16" long.
1979 F150/350 4WD T18 Part Time Drive: 82" long.
1979 F150/350 4WD T18 Full Time Drive: 94 1/2" long.
E40D's were introduced in the late 1980's. I don't know if the fitting on the speedo cable for an E4OD will attach to your 1978 speedometer head.
Old Mar 17, 2010 | 09:13 PM
Jermafenser's Avatar
Jermafenser
How is he going to screw the cable in a E4OD, seeing as the E4OD doesn't have drive gear to begin with? The '90s trucks had electronic speedometers.
Old Mar 18, 2010 | 07:08 PM
terceslil's Avatar
terceslil
D4TZ17260E .. Speedometer Cable & Housing Assy C4/C6 / 73 1/4" long / Obsolete
Fits: 1973 F100/250 2WD from serial number S00,001 / 1974/79 F100/250 2WD / 1973/78 F350 / 1979 F350 2WD.
No one in LA, AR, MS has any.
JOHNSTON FORD-MERCURY in New Boston TX has 1 = 903-628-2513.
GLOFF FORD-MERCURY in Clifton TX has 1 = 254-675-8369.
B.F. WHITE MOTOR CO. in Stanton TX has 1 = 432-756-3321.
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
JST AUTOMOTIVE in Lebanon TN has 3 = 615-443-3086.
VINTAGE PARTS in Beaver Dam WI has 194 (!) = 877-846-8243.
Vintage Parts wants $75.53 + $19.95 (shipping) = grand total of $95.48.
I am headed to the shop out back to get some white lithium in the old speedometer cable. If that isn't motivation to fix your old cable, I don't know what is.
Old Mar 18, 2010 | 11:04 PM
starmilt's Avatar
starmilt
The speedo cable goes in the tcase, but E40Ds came out before 92 and thats when the speedo went to the rear.
ct50f1
20
Feb 17, 2017 09:20 AM
norman2012
Jul 25, 2016 08:37 AM
schoo
May 31, 2016 09:10 AM
three on the tree
Mar 9, 2016 10:13 PM
frank_1
Aug 18, 1999 07:07 PM
