Longer Speedometer Cable needed
Old Mar 17, 2010 | 08:40 AM
Ongoingshow's Avatar
Ongoingshow
Hey guys where would I find a longer speedo cable for these trucks?
Old Mar 17, 2010 | 11:34 AM
terceslil's Avatar
terceslil
I have the same problem. I've made a couple of trips to different parts stores and they keep giving me a 76" speedometer cable with the Pioneer brand part # CA-3011. I have a 78 F250 with a 400M with a C6. The first one would not plug in properly and the second came loose on the first corner that I turned. Certainly they make a cable that works better than what they're selling me.
Old Mar 17, 2010 | 11:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Uh...you need to be specific when asking a question like this.
1973/79 F100/350: There's about 12 different speedo cables.
What's the application...year, series, 2WD or 4WD, transmission type?
If you're doing a swap, I need to know what was original, what you're swapping, so I can figure out the correct length.
Old Mar 17, 2010 | 11:44 AM
terceslil's Avatar
terceslil
1973/79: There's about 12 different speedo cables.
Thread jacking:
I have a 1978 Ford F250 2WD, 400M, C6 Automatic
Old Mar 17, 2010 | 11:53 AM
NumberDummy
Originally Posted by terceslil
Thread jacking:
I have a 1978 Ford F250 2WD, 400, C6 Automatic
D4TZ17260E .. Speedometer Cable & Housing Assy C4/C6 / 73 1/4" long / Obsolete
Fits: 1973 F100/250 2WD from serial number S00,001 / 1974/79 F100/250 2WD / 1973/78 F350 / 1979 F350 2WD.
No one in LA, AR, MS has any.
JOHNSTON FORD-MERCURY in New Boston TX has 1 = 903-628-2513.
GLOFF FORD-MERCURY in Clifton TX has 1 = 254-675-8369.
B.F. WHITE MOTOR CO. in Stanton TX has 1 = 432-756-3321.
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
JST AUTOMOTIVE in Lebanon TN has 3 = 615-443-3086.
VINTAGE PARTS in Beaver Dam WI has 194 (!) = 877-846-8243.
Old Mar 17, 2010 | 12:10 PM
starmilt's Avatar
starmilt
I have a really dumb question. Why would turning a corner make a speedo cable come loose.
Old Mar 17, 2010 | 12:16 PM
terceslil's Avatar
terceslil
Thanks, NumberDummy!
It's funny that the Ford part is 73 1/4" long and the after market one that is not working is longer. Your after market manufacturers must not be building them quite right to make a good connection.
Here are the aftermarket part numbers for anyone who wants to give them a chance:
RockAuto: ATP Part # Y806 {#E6ZZ17260A}
Autozone: CA3011 (76")
OReilly: CA3011 (76")
Napa: Balkamp 6151625 (76")
CA3011 did not work for me.
Old Mar 17, 2010 | 12:18 PM
terceslil's Avatar
terceslil
I don't know. I think that the after market cables do not have good connectors. We had a real hard time connecting it behind the speedometer with the speedometer out of the dash.
As soon as I got on the interstate, it stopped working (came loose). Crappy connectors?
Old Mar 17, 2010 | 12:24 PM
NumberDummy
E6ZZ17260A = 72 3/4" long / Fits: 1986/91 Mustang/Capri 302 (5.0L) with AOD.
Aftermarket cables are known in the autoparts biz as fitzall's. The problem is, they dont fit all!
Old Mar 17, 2010 | 12:26 PM
terceslil's Avatar
terceslil
E6ZZ17260A = 72 3/4" long / Fits: 1986/91 Mustang/Capri 5.0L AOD.
I knew the part number looks nothing like your part number. That's what RockAuto is giving for the part number. Guess who's not buying the speedometer cable from RockAuto.
Old Mar 17, 2010 | 12:27 PM
82ford302's Avatar
82ford302
i bought the 118 incher from napa in october last year. havent had a problem with it yet in my 76. i think it was less than 30 bucks at the time i bought it.
Part number for the cable i used was 615-1628
Last edited by 82ford302; Mar 17, 2010 at 12:41 PM. Reason: added part number for speedo cable, was longer i guess
Old Mar 17, 2010 | 12:34 PM
NumberDummy
I know that...I was just surprised that Rock Auto lists one for a 1973/79 F100/350 that originally fit '86/91 Mustang/Capri's...with an AOD.
It might work, or maybe not. Quien sabe?
Ford is in-famous for replacing 10's of 1000's of part numbers EVERY year!
But....Ford did not replace D4TZ17260E with E6ZZ17260A. So if you wanna use it...lotsa luck.
Old Mar 17, 2010 | 12:41 PM
terceslil's Avatar
terceslil
Maybe out of curiosity, I'll climb under a mustang at the junkyard to see if it looks the same, but I won't be buying this part for my truck.
Old Mar 17, 2010 | 01:40 PM
Ongoingshow
Ok the truck that I have has a 351M and it had a T18 manual with 4x4 and now it has the same 351M but it has an E4OD bolted to it and the transfer case that was on the
E4OD is also under there. I would only need like 4" for it to be long enough but that just doesn't cut it. It's a 1978 single cab long bed with a 4" lift on it.
Old Mar 17, 2010 | 05:37 PM
terceslil's Avatar
terceslil
Sorry for hijacking your thread, Ongoingshow
