in cab hood release
Old Mar 8, 2016 | 07:51 PM
three on the tree's Avatar
three on the tree
Question in cab hood release
have 78 F150 , have seen the Broncos with in cab hood release pull leavers, will they work on the trucks with a longer cable and were can I find the different hood release and inside cab lever? any info would be appreciated
Old Mar 8, 2016 | 08:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In 1978, Ford introduced a locking hood kit for F100/350's and Bronco's. Could be retrofitted to 1973/77 F100/350's.
All the parts are the same for both. Econolines also got a locking hood kit, but only the latch is the same as F100/350/Bronco.
The F100/350/Bronco locking cable is also the same as 1975/76 Granada/Monarch.
All the parts are obsolete, only a few latches are available NOS, everything else is not available.
Old Mar 8, 2016 | 09:04 PM
three on the tree
lol have a hard time with obsolete lol
guess ill leave it factory
Old Mar 9, 2016 | 12:21 AM
hoss73ford's Avatar
hoss73ford
In cab or in car hood cable release types have been a curse on me. Several times I've been locked out of my hood due to faulty cables or latches. No thanks.
Old Mar 9, 2016 | 07:26 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you posted an add here in the WTB section? WTB - Parts & other - Ford Truck Enthusiasts Forums I have sold 2 used ones that way...sorry I do not have any at this time either.
They are a nice and sometime required option, depending on where you live. And yes the cable is small and can break easily. Then you have a pita time getting the hood open.
Imagine a under the hood fire and that little cable breaks.
78/79 Bronco and 73-79 truck for the most part have the same front clip, so if you can find on on a 78/79 Bronco it should swap right over.
Get the locking hood latch truck part or from a van and mod a none locking 80's and up ish T handle cable?
Old Mar 9, 2016 | 11:23 AM
HoustonDave's Avatar
HoustonDave
Pretty sad... can't tell you how many cars I have had with hood latches and have never, ever had one break a cable. First was bought I believe 1978 ('68 Mercedes sedan) and covers VW, Renault, Dodge, Isuzu, Hyundai, Triumph, Ford, Pontiac, Chevrolet, Geo that come to mind since then... but Ford TRUCKs break?
Old Mar 9, 2016 | 12:04 PM
77&79F250's Avatar
77&79F250
Well HoustonDave you are the lucky guy then, I have seen a couple of 73-79 Ford truck ones break over the years and one was at a VERY bad time to have you hood locked.
In my local JY I see the newer 80's none locking T handle set up's broke too. Either at the cable crimp area or at the back side of the T handle.
I think a hand brake on a bicycle has a bigger cable. If I was really wanting to put a locking one my truck, I would up grade the cable for sure.
Old Mar 9, 2016 | 12:29 PM
HoustonDave
Probably true... too, there is maintenance that has to be performed on them too and I'm pretty strong o that. Too, '70's Fords were not real strong on detail quality control - kept me fed like that when I worked for a Ford-Fiat dealer. Work galore!
Old Mar 9, 2016 | 12:33 PM
77&79F250's Avatar
77&79F250
Yes and if the hood is not set to "pop" when the handle is pulled and you need to do the Ford truck hood tap on the sweet spot trick...... Hard to do pull the handle and tap the hood at the same time.
Old Mar 9, 2016 | 12:38 PM
NumberDummy
Which gave more trouble, Fix Or Repair Daily or Fix It Again Tony?
Old Mar 9, 2016 | 06:40 PM
77&79F250's Avatar
77&79F250
First On Race Day
Found Out Running Dale
Fabulous Off Road Driving
Found Offroading Rescuing Dodge
Forever On Road Driving
Flying Out Right Dude
For Only Real Drivers
Fastest On Race Day
Found On Road Daily
Fond Of Resonating Decibels
Fastest On Road, Dip!
Found Off Road Driving
Fix Orally Repulsive Dummies
Lol
Old Mar 9, 2016 | 08:49 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
First On Race Day
Fastest On Race Day
Found On Road Daily
Fording Our Rivers Daily
Old Mar 9, 2016 | 10:13 PM
brian1080's Avatar
brian1080
I installed a locking latch in mine for primary theft deterrent. I have enough room through the fender wells if I have a problem, but I don't want my truck to be stolen.
Gembone
13
Mar 27, 2013 08:55 AM
v8xploder
1966 - 1977 Early Broncos
Feb 6, 2007 04:14 PM
dixiemudder04
16
Jul 7, 2006 04:34 PM
ivanribic
Nov 26, 2003 08:36 AM
mt11867
1997 - 2003 F150
Aug 25, 2002 11:35 AM
