Sponsored by: Real Truck
wheel spacers ?
Old Mar 16, 2010 | 06:30 AM
Badford's Avatar
Badford
wheel spacers ?
I just installed some new wheels & tires 305/55/20 BFG A/T on tight turns they rub on the leaf springs. anyone used spacer to fix this prob? I think a 1/2" spacer will correct the issue.
Old Mar 16, 2010 | 06:50 AM
Rando Commando's Avatar
Rando Commando
Wheel spacers are bad news my friend. You'll lose some threads for your lug nuts, not to mention that you have this piece of aluminum behind your wheel, which can become a liability.
Old Mar 16, 2010 | 09:39 AM
Badford's Avatar
Badford
I know everyone says spacers are bad, but has anyone actually ever used them and had a problem? as long as there is enough thread left what could go wrong?
Old Mar 16, 2010 | 11:25 AM
cartmanea's Avatar
cartmanea
The best option would be to get wheels with the correct offset. 0 to -12 offset would be best for that tire and year truck. Another option is to drill and tap the wheel turn bump stops and put a bolt in them to limit your wheel turn. What wheels are you using?
Old Mar 16, 2010 | 01:25 PM
dkf's Avatar
dkf
Video on wheel spacers. YouTube - WHEELS AND SPACERS
Old Mar 16, 2010 | 03:49 PM
Hybris's Avatar
Hybris
Good vid answered a bunch of questions I have had save for one.
Wheel spacers and heavy weight towing (near or at max truck capacities) how do they react?
Old Mar 16, 2010 | 03:56 PM
dkf's Avatar
dkf
Never used wheel spacers myself. In the vid he mentioned the steel spacers vs the junk aluminum spacers. With a good quality steel hubcentric spacer I would say your good to go and tow up to the manufacturers recommended weights.
Old Mar 17, 2010 | 01:15 AM
kengarchow's Avatar
kengarchow
i have 07 wheels on my 99 and started with the regular non hub centric spacers and had bad vibs
bought the hub centric set and have had no problems now for about 20K mi
Old Mar 17, 2010 | 07:30 AM
aldridgec's Avatar
aldridgec
That's probably the best video I've seen from that guy. Some of them I have debatable technical information, but this is 100% and very very good advice.
darkjedi351
May 22, 2016 02:09 AM
mossyoakford96
Aug 27, 2014 09:16 PM
reg1952
23
Nov 12, 2012 12:09 PM
pwauburn
17
Feb 16, 2012 08:31 PM
Builttough 89
Dec 8, 2006 11:24 PM
