Trans fluid change
Old Mar 13, 2010 | 12:19 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Trans fluid change
Hello all, I plan on changin my trany fluid today and was wonderin if I
need to replace the filter when I do it? I read somewhere that the filters
on these are pretty good and dont need changin for a while. I have a 01
F250 with 83,000 on it. What trany do I have and what fluid do I need to
put back in? Thanks for the help.
Last edited by Stroker 94 1/2; Mar 13, 2010 at 12:20 PM. Reason: put wrong year of truck
Old Mar 13, 2010 | 12:25 PM
onelionhunter's Avatar
onelionhunter
Filter
I would do the filter while you are there, they arent that expensive.
Here is a link to changing the fluid, I have done 3 trucks this way now.
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old Mar 13, 2010 | 12:57 PM
danskool's Avatar
danskool
Go Bills !
That is a nice article.. I changed my filter a couple years ago when i did my TC.. This spring i am going to just flush it. I will do this every couple of years. I average about 8 to 10k a year. Every spring Change motor Syn Oil. Every other flush Trans. This is the oil i used and was recommended to be just fine..
Old Mar 13, 2010 | 01:59 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
I use NAPA ATF also.
Old Mar 14, 2010 | 07:06 AM
gtnwood's Avatar
gtnwood
If I have my tranny power flushed, how important is it to change the filter?
Old Mar 14, 2010 | 07:59 AM
Izzy351's Avatar
Izzy351
DON'T power flush it... Just use the method of pulling the return line from the cooler and running clear hose to a catch container. Use the motor to pump out the pan, and when you see LARGE bubbles in the line, stop and refill the pan (6-7 quarts). As the motor runs, cycle through the gears.
I run full-syn Mobil1 Mercon V. Ford discontinued the use of Mercon (even though some companies still make it), and changed the Mercon V specs to work with our transmissions several years ago. I switched back in '08 and have been abusing my stock trans pretty hard with no issues (knocking on wood!).
Old Mar 14, 2010 | 02:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Not very important. This is a boulder catcher, not a fine filter. If there is enough junk to plug the filter the trans is already toast.
Old Mar 14, 2010 | 02:51 PM
big poppa's Avatar
big poppa
Not to hi-jack but while your here Mark, would a nice trans filtering system be good to catch all the clutch dust and other contaminates thats floating around in there?? Its time for me too soon so I thought why not do it while I'm in there, thanks as always.
Old Mar 14, 2010 | 05:51 PM
gtnwood's Avatar
gtnwood
Well alright then
Jon Thomas
May 19, 2012 03:39 PM
AKCarl
16
Aug 31, 2007 09:11 PM
gergorio
May 29, 2004 03:42 PM
Ford4x4CountryBoy
Mar 27, 2004 08:25 AM
