TGMH
Old Mar 14, 2010 | 11:37 AM
just another truck's Avatar
just another truck
TGMH
Thank God For Manual Hubs!!!
Just drove for 50 mile with the 4x4 high engaged, it would not disengage..Finally it growled a little ( like a bad gear change) and disengaged..
Before I start the search, anything you all would recomend I look at first??
Old Mar 14, 2010 | 11:53 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Your linkage, if you have the floor shifter for the trans. case like mine
Old Mar 14, 2010 | 12:22 PM
just another truck
Thank you, but no, it is the ESOF style..
Old Mar 14, 2010 | 12:43 PM
twags6's Avatar
twags6
Did you try backing up to disengage it? Sometimes it gets bound up to the point it wont disengage right away so you need to pop it in reverse to relieve the pressure. It can even happen with the floor shifter.
Old Mar 14, 2010 | 04:50 PM
just another truck
I did back up, no more then about 10 maybe 15 feet. I have also selected 4x4 and tunred it off about 6 or more times since.. who knows.. but it is working now..
Old Mar 14, 2010 | 06:01 PM
twags6's Avatar
twags6
Well, on the electrical side of things, you can check out the ESOF relays, shift motor, wiring, etc. Check for loose or bad components.
Why not change out the fluid too? AFAIK, the stuff in mine was original (156k) and came out kinda brown. I'm not sure if low or dirty fluid would make shifting out of 4wd difficult.
Tomahawk2506
Jun 12, 2012 05:38 PM
PSDx3
Jan 21, 2011 10:25 PM
adam10
Apr 7, 2010 05:54 PM
kona72
Aug 31, 2007 09:26 PM
NDS
Apr 4, 2003 11:28 PM
