Water Pump Going Out?
Old Mar 12, 2010 | 10:43 AM
berry1234's Avatar
berry1234
Well at the light to day I hear this squeak.....squeak......squeak. About every 3 seconds. It doesn't change with engine RPMs and from the hose method seems to be coming from the front of the water pump where the pulley attaches. Does this sound like the water pump bearings are going out?
Old Mar 12, 2010 | 11:08 AM
tinaheel's Avatar
tinaheel
from ur description sounds like it to me
Old Mar 12, 2010 | 10:02 PM
Greyman's Avatar
Greyman
If it is you will start leaking water from under the pump soon. Then you will be sure.
Old Mar 12, 2010 | 10:23 PM
Tees77f150's Avatar
Tees77f150
yup, pump going out, and new pump going in real soon!
Old Mar 13, 2010 | 01:07 PM
berry1234's Avatar
berry1234
Ok. So do I wait for the weapage? I drove her today, no noise. Seems to be intermittent.
Old Mar 13, 2010 | 01:57 PM
bucks77ford's Avatar
bucks77ford
If you have time, just replace it before you have too. When you HAVE TOO always seems to be at the wrong time. If it's not leaking now, it will. Granted, it's not 100% it's your water pump, but most likely.
Old Mar 13, 2010 | 03:54 PM
OrangeJuice's Avatar
OrangeJuice
Yup...get it done ASAP. A long time ago after I got my truck I pulled in home and noticed I had water/coolant draining from the underside of the waterpump. No warning at all...no noise was heard. I guess I lucked-out when it happened at home.
OJ
Old Mar 14, 2010 | 12:43 PM
berry1234's Avatar
berry1234
Thanks. Is Bosch a good brand? It's the only new pump I can find locally. The rest are refurbs.
The Terrible Blob
Sep 2, 2014 10:30 AM
88_F0RD
13
Apr 4, 2014 04:55 AM
Blue94Bronco
1978 - 1996 Big Bronco
Oct 9, 2012 09:21 PM
rmalottwtes30
Jul 19, 2010 03:37 PM
Spirit615
Jul 31, 2005 05:06 PM
