ac Compressor Squeak
Old Jul 19, 2010 | 01:07 PM
rmalottwtes30's Avatar
rmalottwtes30
My AC compressor is starting to squeak. Can anything be done to fix it besides replacing the pump? Can it be lubed up, or change out the bearing, or repack the bearing?
Old Jul 19, 2010 | 02:44 PM
oreocreaming's Avatar
oreocreaming
theres no repacking bearings for them. its all internal. you can TRY to get a can of oil charge from your local auto parts store. they are around 8oz. is it still r12 or converted to 134a already? that will make the difference on that oil charge. you sure its your pump and not just the clutch?
Old Jul 19, 2010 | 02:48 PM
rmalottwtes30
I think it may be the clutch doing it. How can you narrow it down?
Old Jul 19, 2010 | 02:50 PM
oreocreaming
does it make the same noise with the a/c on and off or just on, just off?
Old Jul 19, 2010 | 03:16 PM
rmalottwtes30
On and off it still makes the noise. I sprayed some WD40 behind the ac clutch where it meets up to the compressor and the noise stopped.
Old Jul 19, 2010 | 03:22 PM
oreocreaming
then it's the bearings the belt pully rides on. Buy the clutch set and you'll be alright. If you can that is. Not sure if you can with the older pumps unless you get it straight from ford
Old Jul 19, 2010 | 03:37 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
rock auto has all the parts you need if buying new.check 'em out.
cowmilker08
20
May 17, 2016 08:32 PM
IHbase
Jul 24, 2015 07:37 AM
NMSU_RRAggie
Jun 27, 2015 11:34 AM
mfp4073
1983 - 2012 Ranger & B-Series
Sep 1, 2013 09:36 AM
J.C.
Jun 29, 2001 11:11 AM
