belt sqeaking
Old Mar 31, 2014 | 08:04 PM
88_F0RD's Avatar
88_F0RD
belt sqeaking
I replaced the belt on the 1988 Ford F150 when I replaced the water pump.
it has a auto tensioner.
when driving down the road, after a while the squeak goes away.
when you first start it up and the clutch fan turns on the squeak cannot be heard.
but when the fan kicks off it squeaks until driven for a while.
what else could it be?
I think it may be the auto belt tensioner.
I put my ear next to the belt tensioner (and it seems like that's where the sound is coming from)
is the top of the tensioner suppose to move at all?
the pulley the tensioner is connected to moves, would just replacing the pulley that's connected to the belt tensioner stop the squeak?
what do ya'll think?
Old Apr 1, 2014 | 07:55 PM
F-erOnlyRunsDwnhill's Avatar
F-erOnlyRunsDwnhill
Id go with the tensioner. My 94 4.9L would squeak 2 months after replacing belt. Finally broke down and bought a high quality one and it's been squeak free ever since.
Not sure what you mean by top of tensioner moving.
Old Apr 1, 2014 | 08:20 PM
88_F0RD's Avatar
88_F0RD
belt tensioner
where did you get your tensioner from? how much did you pay?
AutoZone (has one for $54 and a mail in rebate) in stock. with a one year warranty.
I'll post a short video of the tensioner moving. by the looks of it the top part of the tensioner assembly moves slightly.
I saw a video of one of youtube completely worn out on a Chevy motor and the whole tensioner assembly was moving and clicking.
Old Apr 1, 2014 | 08:58 PM
88_F0RD's Avatar
88_F0RD
worn out tensioner video
:worn out on a chevy
: 4.9 the top part of the tensioner seems like it moves a bit.
A buddy of mine was saying just the idler pulley could be replaced. the pulley itself is only $15. and has a bearing inside.
but the tensioner part has a spring and bearing inside. and comes with the pulley.
Old Apr 1, 2014 | 08:59 PM
F-erOnlyRunsDwnhill
I've never replaced my tensioner, I was talking about the belt. Sorry should have clarified. For whatever reason my truck would eat up the cheap duralast belts. Finally got the most expensive one they had. Ran about $36 I believe. But no squeaks yet.
I'm assuming you mean where the tensioner mounts to the block? If so that should not move at all. Get one with a lifetime warranty, better safe than sorry and you get what you pay for.
Old Apr 1, 2014 | 09:03 PM
F-erOnlyRunsDwnhill
Just watched the vids. The second one is exactly how mine would sound when I started it up cold. It would go away after awhile when it warmed up. An easy test to see if it's the belt or a bearing is have the engine running and pour a small amount of water on to the belt. If sqeaking stops it's the belt, if not then likely a bearing some other place. I would just get a high quality belt. Maybe it got some antifreeze/oil on it when you replaced the water pump causing it not to grab correctly?
Old Apr 1, 2014 | 10:16 PM
88_F0RD's Avatar
88_F0RD
engine detailing
I had replaced my water pump and put in a new belt and fan clutch.
Then sometime later I detailed the engine, covered up the battery alternator and distributor with plastic bags.
Wish I would have taken the belt off, because I got the engine detailing gel on the belt.
it squeaked really bad.
So I got a new belt (cleaned the other one off with brake cleaner and saved in just in case I need it one day, put in in the door panel).
And then I cleaned all the pulleys off with brake cleaner and a brush (carb cleaner works too).
The only squeak now, I think is the tensioner.
It seems like I just take the belt off the tensioner without removing the whole belt. and take one bolt out of the auto tensioner. and it looks like that's all there is to it.
because the new belt tensioner comes with the pulley already installed.
if I ever use any spray can detailing gel I'm gonna have to remove the belt and cover the pulleys somehow.
I don't think I will do that again though, it looks nice, but not worth the headache.
Old Apr 1, 2014 | 10:19 PM
F-erOnlyRunsDwnhill
Yeah they are pretty easy to swap out. Let us know how it goes
Old Apr 3, 2014 | 04:29 PM
88_F0RD's Avatar
88_F0RD
replaced belt tensioner today
It was easy. Only took about a hour. that's after I read the instructions and found some instant Krazy! Glue.
The old tensioner has one locator pin. the new one comes with a bushing and a allen head screw your suppose to JB weld, metal cement, or bond (the bushing over the allen head screw).
tools used : 5/8 wrench 3/4 wrench and a 15mm Wrench (the new adjuster pulley on the auto-tensioner is a 15mm wrench (aftermarket I guessed why)
I didn't notice it until I bought the new one but there is a plastic bushing that runs around the autotensioner and it was obvious by comparing the old one to the new one that, the bushing had worn out.
I cant post photos or I would.
Old Apr 3, 2014 | 06:19 PM
F-erOnlyRunsDwnhill
Nice! So you're now squeak free?
Old Apr 3, 2014 | 07:10 PM
88_F0RD's Avatar
88_F0RD
squeak free!
$67 dollars later, yep. I went with the expensive tensioner like you suggested. belt tensioner made by dayco made in the usa. matched with a dayco belt.
other videos online looked complicated on changing this part, really simple, one bolt, and one pin to line up. easy install.
thanks dude.
Old Apr 3, 2014 | 08:39 PM
mrrish79's Avatar
mrrish79
Great thread the second video is the exact sound i have.
Old Apr 3, 2014 | 11:31 PM
F-erOnlyRunsDwnhill
Cool, no problem bro that's what we are here for. I'm jealous of that clean engine you got there lol. Gonna have to scrub mine down. Living in the desert if any kind of oil leaks anywhere the dirt sticks to it like a magnet. Makes everything look gross.
Old Apr 4, 2014 | 04:55 AM
88_F0RD's Avatar
88_F0RD
2nd video of what the belt sounds like after new belt tensioner installed
powerstroker100
15
Jul 10, 2015 02:46 PM
Dennis Anderson
Dec 17, 2014 04:46 PM
DGM
May 17, 2012 07:36 PM
4wydnr
Dec 30, 2008 05:27 PM
pipesalesman
Feb 6, 2007 01:28 PM
