problem with edge programer
Old Mar 10, 2010 | 08:42 PM
stx4x4's Avatar
stx4x4
have a 04 f150 stx 4x4, put truck back to stock, did the onboard diagnostic check, had an error, P1000 OBD II Monitor Testing Not Completed. now i get a notice on monday that i have to take truck for emisions test here in illinois, well went to go clear teh code with edge product, and it didnt clear, any options or ideas what to do? edge said to leave in stock, and let it run 2-3 cycles, what ever that means, any one else have this problem? or know what to do ? please help thanks Rob
Old Mar 10, 2010 | 08:55 PM
1bad67sbf's Avatar
1bad67sbf
i have an edge evolution also and edge says all products (gas at least) should pass emissions unless you unlock it (but they also recommend you return to stock for test) that is something you should talk to edge about
07 f150 crew w/ specter intake, edelbrock sdt cat back, and edge evolution (wheels and tires in the mail )
Old Mar 10, 2010 | 08:58 PM
stx4x4's Avatar
stx4x4
unlock?
thanks for the advice, what do you mean by unlock it?
Old Mar 10, 2010 | 09:16 PM
1bad67sbf's Avatar
1bad67sbf
sorry dont worry about that i realized the hot unlock is just for dsl not gas
but it is an extra perf level
Old Mar 10, 2010 | 09:20 PM
stx4x4's Avatar
stx4x4
thanks
thanks bad 67, just worried about getting that emisions done, just trying to figure out how to clear that code, thanks again!
Old Mar 10, 2010 | 09:56 PM
pb34's Avatar
pb34
You'll be fine with the Edge and emissions testing. I had my truck tested last week and I left it programmed but just unplugged the unit so they could use the OBD II port. I passed with no issues.
I'm not sure how to help with your code problem though.
Old Mar 11, 2010 | 12:17 PM
shotgunz's Avatar
shotgunz
Here's the drive cycle requirements to clear the P1000 code:
Ford Motor Company Driving Cycle
Old Mar 11, 2010 | 08:03 PM
kevincw's Avatar
kevincw
shotgunz is correct, the P1000 code just says that there is not enough information and it must be driven to check itself. This happens when you clear codes or switch programs.
Old Mar 11, 2010 | 08:15 PM
Zmann's Avatar
Zmann
correcto mundo ! just like if you unplugged the battery .. it has to complete a cycle
stx4x4
2004 - 2008 F150
Sep 30, 2010 08:55 AM
stx4x4
2004 - 2008 F150
Mar 15, 2008 06:18 PM
stx4x4
2004 - 2008 F150
Dec 2, 2007 01:54 AM
stx4x4
2004 - 2008 F150
Mar 17, 2007 07:18 AM
stx4x4
2004 - 2008 F150
Jun 30, 2005 07:56 PM
