Edge fault code showed
Old Mar 16, 2007 | 10:06 PM
stx4x4's Avatar
stx4x4
Question Edge fault code showed
finally got edge running, did the self diagnostic test had a error code of
P1000 OBD-II monitor testing incomplete, i called edge they aid to run the truck a few more times under normal temperature conditions and it should go away, i trieds to clear it and it wont came back up, had any one with edge had this problem?
Old Mar 17, 2007 | 06:54 AM
mik369's Avatar
mik369
I'm having same issue to. Yesterday edge flashed 3 DTC 's pulled the codes returned it to stock tune now it pulls P 1000 test incomplete it did it before when at the dealer they said it had a blown pcm fuse I find it hard to believe so now I'm searching to..
Old Mar 17, 2007 | 07:18 AM
projectSHO89's Avatar
projectSHO89
A P1000 code is COMPLETELY NORMAL after a PCM reset until such a time as ALL of the OBDII diagnostic monitors have run.
The actual time to execute all the tests will vary from a few days to a few weeks (I had one take six weeks once) depending on your local weather (several tests require the temperature to be above 50F) and on how the truck is driven.
Go drive your truck and quit putzing with it.
Steve
eaglefire21
25
Dec 5, 2016 12:36 PM
factionos
Crossovers
May 19, 2015 09:16 PM
Super Dirty Greg
Nov 2, 2014 03:25 PM
jonathonjeremiah
Jun 6, 2012 11:29 PM
peglegger
Feb 27, 2011 11:50 PM
