Dummy, help! Carb ID needed
Old Mar 7, 2010 | 05:41 PM
CougarJohn's Avatar
CougarJohn
My 67 240 manual choke is stumbling badly and is in need of a carb rebuild. The carb on the engine doesn't look like the Autolite Carbs 1101 and 1100 shown in the factory manual ( page 10-52-53).
My casting says "Autolite" with the main body cast as GR 3507 8. There is also a remanufactured by Holley tag reading 64-5164.
I see rebuild kits for Carter YF for my year but the gaskets don't seem like they would work. Why is everyone shouting "Carter" when the original carb was "Autolite"?
Can you guys ID the carb for a kit? Should I just buy a rebuilt carb for the original 67?
Semper Fi
Old Mar 8, 2010 | 04:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Semper Fi
In 1970, Ford replaced all the Auto-Lite 1V's used on 1962/69 cars/trucks with carbs that do not match what they looked like in previous year shop manuals.
The carb kits, gaskets and some internal may not the same, it depends on what carb was used.
But, without the tag number, I dunno what carb you have. Does your truck have a M/T or an A/T? With or without a smog pump?
Carter carb parts will not work on Holley, Auto-Lite or Motorcraft carbs.
Old Mar 9, 2010 | 12:20 PM
CougarJohn's Avatar
CougarJohn
It has a C4 automatic transmission, no smog, no tag. It has manual choke, but I see the provision for an automatic choke that has been removed.
It sounds like my best bet is to buy a rebuilt carb and start over.
Thank you, Bill.
Old Mar 9, 2010 | 12:54 PM
NumberDummy
Just as I thought, this is one of the 1970 replacement carbs. An automatic choke could be mounted...if required.
DOPZ9510M (replaced C5TZ9510P) .. 1V Auto-Lite/Motorcraft Carburetor (Motorcraft CA357A) / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Want a NOS genuine Ford original?
C5TZ9510P = DENNIS CARPENTER NOS OBSOLETE PARTS has ONE = 704-786-8139.
Ppl think that Dennis Carpenter only sells repro parts, but the fact is...Carpenter has the second largest stock of obsolete Ford parts on the planet.
Green Sales Co in Cincinnati OH has the largest stock.
Old Jan 2, 2013 | 12:11 AM
AlamedaGreg's Avatar
AlamedaGreg
Hello all. I'm new to this game and am learning about my 65 F100 stepside retirement gift to myself. I have no tag on the carb. It is stamped autolite on the bbl on one side and
"68
3507
P"
on the other side. Any help you can give this rookie would be great. 3spd manual tran. Runs but parts and screws missing from carb. Thank u for your time.
Old Jan 2, 2013 | 04:33 AM
NumberDummy
Originally Posted by AlamedaGreg
Hello all. I'm new to this game and am learning about my 1965 F100 Flareside retirement gift to myself. I have no tag on the carb. It is stamped autolite on the bbl on one side and
"68 3507 P"on the other side.
Any help you can give this rookie would be great. 3 spd manual tran. Runs but parts and screws missing from carb. Thank u for your time.
Welcome to FTE
Is it a 240 or 300 I-6, or a 352 2V? / I asked a mod to move your post to the 1961/66 forum, since you don't have a 1967/72.
Old Jan 2, 2013 | 06:07 AM
willowbilly3's Avatar
willowbilly3
Cougerjouhn, those over the counter remanufactured carbs are a crap shoot. As a shop owner, I had to quit using them a long time ago because they were just junk. I had bought a Holley (Carter YF) reman once from a supplier who insisted it was as good as brand new. It wasn't. I'm sure I put way more work into getting it running right than Holley ever did into "remanufacturing" it. It would be worth scouting out a good original core, with tag, and having a reputable local shop rebuild it, if the Dennis Carpenter one doesn't pan out for you.
Old Jan 2, 2013 | 07:09 PM
CougarJohn's Avatar
CougarJohn
Thank you, Willow. This is a two-year-old post that has been resurrected.
I pulled the carb down and went to an upscale auto parts shop and found a guy at the counter who seemed conscious. All I wanted was a kit with the proper gasket and accel pump and I got that. I did the rebuild myself, old school.
Old Jan 2, 2013 | 07:16 PM
Honkey Lips70's Avatar
Honkey Lips70
NumberDummy,
I need your help identifying a proportioning valve/distribution block, I don't know how to private message you or I would have, but do you think you can check out the thread I posted today, you seem like the man with all the answers around here.
Thanks
Matt
Old Jan 3, 2013 | 03:25 AM
NumberDummy
Originally Posted by Honkey Lips70
NumberDummy,
I need your help identifying a proportioning valve. I don't know how to private message you or I would have, but do you think you can check out the thread I posted today.
Click on members user name for contact info. See my post in your other thread.
Bartsteltzer
38
Oct 26, 2016 04:36 AM
hooler1
Jan 16, 2016 08:52 PM
SlickWiSlick
Feb 19, 2009 10:13 AM
cdherman
Apr 29, 2004 12:44 PM
cdherman
Oct 5, 2003 04:07 AM
