351 or 302?
Old Feb 28, 2010 | 12:26 PM
BigD7575's Avatar
BigD7575
351 or 302?
Hello everybody,
Dont mind me cuz this is a little bit of a stupid question but, my friend has a 90 F150 2x4 but we cant tell how to find out what engine is in it! 351 or 302?
Thank you
Old Feb 28, 2010 | 12:44 PM
jroehl's Avatar
jroehl
Open the hood. The intake plenum (upper intake manifold) will either say "5.0 Liter" (302) or "5.8 Liter" (351) on it.
If it for whatever reason doesn't have a stamped plenum, and it's the original engine, then look at the 8th digit of the VIN--H is a 5.8L/351cc and N is a 5.0L/302cc.
Beyond that, there are ways to tell them apart based on the deck height/width and so on, but I don't know those off the top of my head.
Jason
Old Mar 1, 2010 | 08:53 PM
EPNCSU2006's Avatar
EPNCSU2006
The EGR tube on the 351 pulls exhaust from the passenger side exhaust manifold. The lower thermostat bolt can be reached with a socket and straight extension on a 351, but is blocked by the water pump/timing cover on a 302.
Old Mar 1, 2010 | 10:26 PM
OLBESSIE's Avatar
OLBESSIE
ACTUALLY the "5.0" wont say 5.0 if its the orginal manifold, it will just say fuel injection. the 5.8l will say it however..., another quick way to tell is check the emissions tag under the hood
Old Mar 2, 2010 | 01:40 AM
TexasGuy001's Avatar
TexasGuy001
I think that on 87-91 it says Ford Fuel Injection and on 92-96 it says Ford 5.0. It should say on the underhood sticker for emissions.
Old Mar 2, 2010 | 03:05 AM
OLBESSIE's Avatar
OLBESSIE
you know i thought that was the case, cause i'm almost positive my buddys 92 bronco actually says 5.0 on it, but i knew if they did do that, it wast till 92 up that they did, so i didnt want to say anything till i knew for sure, cause otherwise id have just added to the confusion. also, someone could have swapped one from a 5.8L, or a mustang...
thanks for the clarification
Old Mar 2, 2010 | 03:50 AM
TexasGuy001
Your right someone could have swapped motors at some point. The Mustang and Crown Vic intakes are different, so it probably still has the truck intake.
Old Mar 2, 2010 | 10:45 AM
DJdemon6696's Avatar
DJdemon6696
my 1990 F250 had 5.8 EFI stamped on it
Old Mar 2, 2010 | 11:09 AM
SaikotikGunman's Avatar
SaikotikGunman
My '95 says 5.0 EFI on the plenum.
There should be a sticker up front that says 5.0L or 5.8L in front of the radiator.
Is there an engine code on the door sticker, I don't recall?
Old Mar 2, 2010 | 05:47 PM
BucksTrucks's Avatar
BucksTrucks
If you can get a socket and ratchet on the bottom thermostat housing bolt its a 5.8, if not its a 5.0
Old Mar 2, 2010 | 09:04 PM
Conanski's Avatar
Conanski
My '90 has "5.0 EFI" on the top of the upper but I can't remember if my '89 did or not.
Old Mar 3, 2010 | 03:43 AM
TexasGuy001
Really? The older trucks I have seen just said Ford Fuel Injected or something to that effect. I'm interested to know what year Ford changed that.
Old Mar 3, 2010 | 05:13 AM
big greeny's Avatar
big greeny
my 95 5.0 also says 5.0 on the intake
Old Mar 3, 2010 | 07:29 AM
jroehl's Avatar
jroehl
Thanks, Paul. I could have sworn that my '90 was the same, but since it's been gone for several years now, I couldn't just run outside and check.
Jason
Old Mar 3, 2010 | 08:28 AM
SaikotikGunman
I'm pretty sure my '87 says Ford Fuel Injection... my '88 was a 300-6, so that doesn't help.
briank
15
Oct 18, 2008 11:07 PM
Ozzie
23
Oct 30, 2007 12:47 PM
pac_302_xlt
22
Apr 10, 2005 06:02 PM
stover007
Mar 16, 2003 09:34 PM
glenn 79
Mar 28, 2001 02:10 PM
