302 and 351W Block
Old Oct 12, 2008 | 06:55 PM
briank's Avatar
briank
302 and 351W Block
Is the 302 and 351W Block the same width??
Old Oct 12, 2008 | 07:35 PM
bob1987f's Avatar
bob1987f
i believe the 351w is an inch or an inch and a half wider
Old Oct 12, 2008 | 09:32 PM
Conanski's Avatar
Conanski
It's probably closer to 3" wider.
Old Oct 13, 2008 | 05:59 AM
MBDiagMan's Avatar
MBDiagMan
Why is the 351 block 3" wider? The deck height is only raised an inch or a half inch. Even if the deck height were raised an inch, it is at a forty-five degree angle, so 1 inch up would only move the head out a half inch on each side, adding one inch to the width at the outer corners of the block deck.
Is there some other part of the block that protrudes out adding the other two inches?
Old Oct 13, 2008 | 06:51 AM
Scndsin's Avatar
Scndsin
Ford Racing Catalogue sez 302=18-3/4 wide, 351= 21 inches wide. Does not say if that is at widest point of deck or with heads mounted.
Old Oct 13, 2008 | 08:22 AM
briank's Avatar
briank
Thanks for the info. The main part I am worried about is at the motor mounts area.
Old Oct 13, 2008 | 09:15 AM
MBDiagMan's Avatar
MBDiagMan
The block mounts into position exactly the same. It is the overall width that we have been discussing.
Old Oct 13, 2008 | 11:11 AM
briank's Avatar
briank
I guess I should have stated my orginal question as, I know the motor mounts are the same. Now when I go to bolt it in where a 302 was will I need to move the mounts/perches on the frame? Is it wider there as well?
Old Oct 13, 2008 | 11:35 AM
Scndsin's Avatar
Scndsin
What he said ^^^
They are the same width in the skirt area.
Old Oct 13, 2008 | 03:57 PM
Conanski's Avatar
Conanski
No and no.
Old Oct 17, 2008 | 10:53 AM
briank's Avatar
briank
Thanks for all the info.
Old Oct 17, 2008 | 03:51 PM
J1MMY's Avatar
J1MMY
(slight) hijack
Will either bolt straight in where a 232 was?
Old Oct 17, 2008 | 10:09 PM
Conanski's Avatar
Conanski
Originally Posted by J1MMY
(slight) hijack
232? what family does that belong to?
Old Oct 18, 2008 | 12:05 AM
82ford302's Avatar
82ford302
3.8L V6. = 232 cubes.
Old Oct 18, 2008 | 01:53 AM
J1MMY's Avatar
J1MMY
Sorry, I should have put 3.8V6 but was being lazy.
Anyways, will they?
