Brake problem?
Old Feb 21, 2010 | 08:56 AM
fastbee's Avatar
fastbee
Brake problem?
Yesterday I attempted to replace the front brake pads on my '05 F-250. The pads are Motorcraft Super Duty pads. First off, the clips were not the same as the ones on the old pads. The old clips were "reversed", definately one for each side while the new ones were all the same and had to be installed upside down on one side...they seemed to fit and work but just seemed odd. Second, after I got everything apart, it wouldn't go back together. I compressed the caliper as far as I could but the new pads wouldn't go on the rotor. How far should the caliper retract? I could still see the seals stricking above the face, is that normal or should it be replaced? I put the old pads and clips back on (they are still OK for awhile) until I could get some more info. Are there any tutorials or anything out there for this job? I have found many things for pre-'05, but nothing for '05 and up (which have different brakes).
Old Feb 21, 2010 | 10:53 AM
dschuffert's Avatar
dschuffert
I did all four wheels last summer. I have the same model year as you. I bought all Motorcraft pads from my local dealer and I don't remember having these issues. The metal clips came in a sealed plastic bag in the box with the pads. Everything fit right up without issues. I wonder if the dealer gave you the wrong set of pads?
Old Feb 21, 2010 | 12:25 PM
Sark's Avatar
Sark
Thumbs up
I didn't have any trouble replacing the front or rear pads. Once I got the calipers off I used a small piece of 3/8" plywood & a "C" clamp. I put the plywood piece against the piston & then started turning the clamp until the plywood bottomed out. This gave me plenty of room to slide the caliper with pads over the rotor.
I used the Hawk Performance SuperDuty brake pads (Ferro-Carbon) #HB302P.700 for the fronts & # HB303P.685 for the rears.
Old Feb 21, 2010 | 12:39 PM
gearloose1's Avatar
gearloose1
If the calipers don't easily retract, it is time to pull the caliper and take it apart.
If the cause of the sticking is rust or corrosion on critical surfaces (e.g. on the piston) or the caliper itself, it is time to chuck them for a new one.
I am of the opinion that in any climate that experience corrosion from road salt, etc., calipers should NEVER be just pressed back in, but always rebuilt with new seals, etc. and inspected at the same time.
You did not say where you are --- are you in an area where there are issues with corrosion?
Or, replaced with QUALITY rebuilt calipers.
In your case, if you are not able to push it in... what makes you think the calipers will be free enough (not bind) to perform well?
Often a binding caliper will result in poor braking or uneven wear of your brand new set of pads, and sometimes, damage to the rotor at the same time.
Why not just pull them and rebuild them?
Old Feb 21, 2010 | 01:51 PM
69cj's Avatar
69cj
If your in a high humid area flushing the brake system annually will save you some money and headaches. If in a high snow/salt area annually cleaning and lubing the slide pins is also a good idea.
Old Feb 21, 2010 | 02:06 PM
teppler's Avatar
teppler
I found if you remove the brake reservoir cover when you try to retract cylinder the brake fluid doesn't have to overcome the air trapped in the reservoir and cylinders move easier. Place a towel over the open top to keep fluid from splashing out under the hood.
Old Feb 21, 2010 | 06:17 PM
fastbee's Avatar
fastbee
[quote=gearloose1;8544126]If the calipers don't easily retract, it is time to pull the caliper and take it apart.
Calipers retracted fine, no sticking that I could see. I'm just not sure how far is far enough.
I live in East Tn. We've had quite a bit of cold and snow this winter, but from what saw, the slides and everything looked fine.
I've also read somewhere that the '05 up will flush themselves, is this correct? What I mean by that is you can simply open the bleed screws and the fluid will begin to come out without vacuum or brake pedal depression.
Old Feb 21, 2010 | 09:05 PM
gearloose1's Avatar
gearloose1
Hey, there is NO WAY to know if rust started in the pistons, bores, and the slides without a dis-assembly.
If you are doing dis-assembly, might as well do the rebuild as the incremental time is 10 minutes and the cost of a rebuild kit.
The brake system is suppose to self bleed... but the bug-a-boo is in the ABS unit.
Old Feb 21, 2010 | 09:06 PM
gearloose1's Avatar
gearloose1
Right on.
The only thing I have to add is salt / grime gets inside the pistons / bores, and it just doesn't clean without a removal and rebuild.
BaitGuru
Jan 20, 2015 06:53 PM
chewedtoothpick
Aug 12, 2014 12:41 AM
neilc88
15
Dec 18, 2012 01:23 AM
lrgche
Mar 30, 2011 08:22 PM
MPHorvat
Jul 18, 2010 03:56 AM
