Tow Package?
Old Feb 20, 2010 | 09:54 AM
awq134's Avatar
awq134
Tow Package?
As part of the deal when i bought my truck the dealer put a class-3 hitch receiver on the truck. It has the 4 pin trailer connector right now. how hard is it to install a 7 pin trailer connector? are the wires already pre-ran, or do i have to chase them down myself.
Also, i have a transmission temp gauge, does that mean there's a seperate tranny cooler also?
Old Feb 20, 2010 | 10:17 AM
silver05fx4's Avatar
silver05fx4
if i remember right you can get the 7 and 4 plug from the dealer that just plugs in to the rear harness but i think you will still need to run wires for a brake controler. also their is a few aftermarket product also
Old Feb 20, 2010 | 12:54 PM
awq134's Avatar
awq134
I know my dad had the adapter from the 7 pin on his truck down to a 4 pin that was on his trailer, i didnt' know if there was a reverse adapter or not, I figured i'd have to run the wires to the actual controller. thanks for the input.
Old Feb 20, 2010 | 01:34 PM
skinner24's Avatar
skinner24
The brake controller should wire into a connector that plugs in under the dash. As far as having a 7-pin connector, you will have to get the adapter that plugs into the factory wiring harness on the chassis rail. You can find them at e-trailer.com . They should have anything that you will need to hook it up. Good Luck
Old Jan 14, 2012 | 02:34 PM
Coalroller's Avatar
Coalroller
does anyone know the part number for the 7/4 harness that plugs in to the factory plug on the drivers side right above thee spare tire? It should have a kind of rectangle end to plug into the factor port and the round head on the other end that will plug into the 7/4 pin connector? Any help would be great
Vehicle... 2010.5 f150 with just the factory 4 pin, I have already installed the brake controller and wiring along with the fuse and relay to have trailer brakes and a lead hot now i just need this last part to be finished
Thanks again!
Old Jan 14, 2012 | 04:23 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Try PartsGuyEd He is a site sponsor and his prices and knowledge are second to none. You can find him in the list at the top of the page.
Old Jan 14, 2012 | 08:34 PM
ddrumman2004's Avatar
ddrumman2004
I would assume you have a separate transmission cooler as well. My Ecoboost does.
Just look for it in front of the radiator.
Old Jan 14, 2012 | 09:19 PM
flixden's Avatar
flixden
Just wondering: why a class 3 hitch? That hitch should be limited to 5K lbs, much less than the truck. A class 4 would have been a better choice, I think.
Old Jan 16, 2012 | 04:40 PM
stagalv's Avatar
stagalv
Isn't that the turbo intercooler?
Old Jan 17, 2012 | 12:01 PM
ddrumman2004
The turbo inter-cooler is down low, below the radiator, mounted at a forward angle. It faces the opening in the middle of the bumper.
The transmission cooler will be about half-way of the radiator with two lines connected on the left side, facing the truck.
Old Jan 17, 2012 | 01:04 PM
awq134's Avatar
awq134
because i'm an idiot and wasn't thinking when i told the dealership to install it as part of the deal. The class three is rated to 6,000 per the stamping on it, but with my setup the owners manual states that i can only tow somewhere around 4,400-4,500 i believe.
I'm not really disappointed as i didn't buy the truck to tow a lot, more for the extra bed space for the occasional load that i could never fit into my 4 door pontiac! I've hauled plenty of wood stretching from the trunk all the way out the passenger's side window up front. I must say it's a lot easier to just throw it in the bed and go now!
1L243
All Things Towing
21
Feb 3, 2015 02:52 PM
bossgobbler
Oct 27, 2011 08:18 PM
Patatoe1
Mar 23, 2007 09:21 AM
Garff
Feb 24, 2006 03:39 PM
unmog
All Things Towing
Mar 9, 2004 09:37 AM
