cab-off again!!
Old Feb 22, 2010 | 07:56 PM
  #46
cartmanea's Avatar
cartmanea
An '04 6.9L?
Old Feb 22, 2010 | 09:51 PM
  #47
SrMasterTech's Avatar
SrMasterTech
Opps, My Bad
Originally Posted by SrMasterTech
fficeffice" /><O></O>
Actually, the bedplate seals are a rubber/silicone composite. The front cover gasket is embedded rubber to an aluminum plate. The rear cover uses a seal also. where they connect, you had a bit of silicone sealer. Not just any sealer, but one that does not absorb diesel. I do use the permatex high tack spay on the channels for the bedplate seals. <O></O>
<O></O>
I'm replaced the bedplate seal on an 04, 6.9lit and I am recording for a future video. I take pictures of all the seals for it too.<O></O>
That was my typing malfunction! I admit it! 04, 6.0lit!
Old Feb 23, 2010 | 12:30 PM
  #48
ag-ford-4x4's Avatar
ag-ford-4x4
My floor looks like a dalmation died under teh truck. About 100 little black spots, since I don't park in exactly the same spot every time.
If they told me it was a sensor o-ring..no problem. if they told me the engine or cab needed to come off for the repair...no thanks...ill just live with it.
I had a problem with it when it was doing this when new, but the beauty is, if you wait long enough, its not a new leaking truck, but an old one.
Old Mar 7, 2010 | 08:54 AM
  #49
txmab's Avatar
txmab
I just got back from a 1200 mile drive to K. C. after the bedplate fi 2nd ). Good news is no more oil leak BUT now leaking tranny fluid from the top somewhere I think they may have overfilled it tranny shifts just fine but looks over on the stick like to the top of the plastic gauge.would it purge from a vent or something?
Old Mar 7, 2010 | 12:28 PM
  #50
flamebuster's Avatar
flamebuster
I’m a Senior Master Technician for my local Ford dealer, Diesel and Hybrid certified included. I have worked on the Powerstroke since the 6.9lit. I know these trucks inside and out. You show me a bolt; I’ll tell you where it goes. I have performed every repair possible and I can tell you every shortcut! My point is, pulling the cab is not a drastic operation. It all depends on the circumstances in which you are working and the condition of the vehicle. About the bedplate seal, if it’s back for a second time with the same repair, it was not diagnosed or repaired correctly. They might not have found the actual cause of the leak or failed on assembly. I have performed this numerous times and have never seen a short block cause a leak. If I’m going after the bedplate seal, I would remove the engine, too easy. But that all depends if they have the Rotunda lift, support brackets, etc. The equipment is what dictates the operation. I pull the cab on a 6.0 when it’s seized so I can seperate the flexplate nuts. What matters most, is that if the cab is pulled, always replace the bolts.
Here’s a video on myself repairing a 6.4lit.
YouTube - Extreme Truck Repair
Great video!!! Was always wondering exactly how the cab lift process worked. You put some time into that video. Reps too ya..
Old Mar 7, 2010 | 12:32 PM
  #51
flamebuster
Originally Posted by TRS
Cool video! What repair did you make on the 6.4?
second this one. Was wondering how you guys pull the cab. Took some time to make that video. Thanks for showing us. reps. sent your way.
Old Mar 7, 2010 | 07:42 PM
  #52
SrMasterTech
Failure was
On the video the engine had the high pressure pump fail causing metal contamination through out the entire fuel system. Just about any repair from turbo to below will require the cab to be removed. The procedure is pretty simple actually. Once you remove both batteries, trays, disconnect lower and upper hoses. The master cylinder is removed leaving the hydrolic lines in tact. I will get a closer look at the cab lift with a new video coming soon. check out my newest video of the bedplate seal replacement.
YouTube - Powerstroke 6.0lit Bedplate Seal Replacement HD
Old Mar 7, 2010 | 08:42 PM
  #53
william_04_x's Avatar
william_04_x
Looks like you're putting your new camera to good use. Cool vids.
Old Mar 8, 2010 | 01:33 AM
  #54
flamebuster
anouther excellent video; Also enjoyed the injector removal in the econline. Very good information. I am sure it helps to build confidence for those who want to attempt this themselves...Thanks for sharing...
Old Mar 8, 2010 | 04:59 PM
  #55
hi-jacker's Avatar
hi-jacker
SrMasterTech, I don't know where you are, but is there any chance you could be convinced to move to Missouri?
Old Mar 8, 2010 | 07:54 PM
  #56
SrMasterTech
Reside in Oklahoma
Hey Hi-jacker,
I currently live right next door in Oklahoma. I don't have plans of moving for a few years yet. Although, I'll be heading west to Nevada.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
