is this common
Old Dec 31, 1969 | 06:00 PM
Guest
Guest
Posts: n/a
is this common
Old Nov 10, 2002 | 05:36 PM
Rcmgiasson's Avatar
Rcmgiasson
is this common
My 95 ford f150 with 351w leaks coolant from the front of the engine between intake and heads when it is really cold(from -15 C on). is this common or is this a fairly isolated occurance. what brand of manifold gaskets works best to cure the problem. thanks.
Old Nov 10, 2002 | 07:18 PM
Racerguy's Avatar
Racerguy
is this common
I've seen this quite a few times. When it's cold the gaskets shrink a bit more than normal and start leaking. I work at a Ford dealer so I always use Ford gaskets. They sometimes have McCord stamped on them. Or use FelPro. They are good too.
Old Nov 12, 2002 | 01:38 AM
bourbon's Avatar
bourbon
is this common
i dont think the cure is finding the right gaskets but putting some gasket sealant around each of the coolant passages on the intake in addition to the gaskets themselves.
Apr 13, 2004 12:08 AM
Jan 14, 2002 09:06 AM
1978 - 1996 Big Bronco
Jun 15, 2001 11:33 AM
Mar 11, 2001 10:13 PM
