cab-off again!!
Old Feb 17, 2010 | 01:23 AM
rollerstud98's Avatar
rollerstud98
Originally Posted by Troy Buenger
I believe most shops pull the cab when replacing a motor. The other method is to literally remove the front portion of the truck, ie grill, radiator, etc...
Went by the Ford garage a couple of months ago to pick up a fuel filter and saw 3 trucks with the cabs lifted. It's deffietely not a pretty sight. Either way it's a damn shame with the cost of these trucks to have these type of issues.
Dont they have to remove the grills and headlights and everything else to lift the cab as well? i was in my dealer and I asked the tech about which he preferred when he had an engine out, he said that he wouldnt lift the cab if he was pulling the engine anyways. but all techs are different
Old Feb 17, 2010 | 01:47 AM
cartmanea's Avatar
cartmanea
A good tech can have a cab off in 45 minutes, it makes working on and around the engines a lot easier.
Old Feb 17, 2010 | 09:12 AM
rollerstud98
yes i know, but if they are pulling the motor anyways it just seems unneeded. opinion of my tech and of myself.
Old Feb 17, 2010 | 05:08 PM
txmab's Avatar
txmab
I went to the shop(they're pretty good about access) at the first leak, my cab was 8' in the air, YIKES!! the tech said it's the best way ,that's how they build them at the factory .Also, there's only a couple of plugs to disconnect, BUT, p/s res. comes out a/c gets pumped down, front grill comes out but rad. stays in,then it's just the bed and chassis on the ground..Ihave the ex. cab xl model 18'' rims w/toyo 285 75 r18 .
Old Feb 17, 2010 | 06:17 PM
satwood's Avatar
satwood
Do we have a cab off procedure posted here in the database somewhere? It seemed like a daunting thinkg to me but it sounds easier than I feared from your comment.
Thanks
Steve
Old Feb 17, 2010 | 06:36 PM
txmab's Avatar
txmab
they had two others cab-off, pretty standard at that shop evidently.Guess it all boils down to how particular we are .like I said I had no issues with the first surgery . makes this one seem easier somehow.
Old Feb 17, 2010 | 08:11 PM
FishOnOne's Avatar
FishOnOne
No... Removing the cab is mostly disconnecting stuff (the simplified response)
Old Feb 17, 2010 | 09:18 PM
rollerstud98
so is pulling a motor
Old Feb 17, 2010 | 09:30 PM
rollerstud98
I'm not against pulling the cab, I just don't see the point of it if the motor is coming out anyways.
Old Feb 17, 2010 | 09:39 PM
dlibson's Avatar
dlibson
Work on one, and you'll understand. Until then, you won't...
Old Feb 18, 2010 | 12:20 AM
cartmanea's Avatar
cartmanea
After laying on top of my engine to remove the turbo, I realized everything would be a lot easier with the cab out of the way.
Old Feb 18, 2010 | 01:08 AM
rollerstud98
i have worked on mine, and will be working on it soon again. yes working on the turbo just having to do that is easier to get around with the cab off. all i'm saying is that if the motor has to come out anyways, why lift the cab? thats what my tech said to me.
Old Feb 18, 2010 | 01:36 AM
  #28
cartmanea's Avatar
cartmanea
Because its a lot easier to disconnect everything on the motor and get all the exhaust pipes reconnected without leaks.
Old Feb 18, 2010 | 01:53 AM
  #29
rollerstud98
I'm just telling what my tech told me, he will not lift a cab if he is pulling the motor, and every time I've been in my dealer I have not seen a 6.0 with the cab off, just the 6.4
Old Feb 18, 2010 | 08:20 AM
  #30
69cj's Avatar
69cj
Originally Posted by joe blow
I have learned to live with a few leaks....If you want a leak free car go buy a japanese vehicle...they have the leak problem solved.
I periodically inspect my truck for new leaks and wipe as I go. I'm not sure what you guys expect from a badly designed, flaw filled engine?
Granted the only leaks I really have is a collection of a few drips at the bellhousing and a little bit of oil on the sides of the heads...not sure what it is from but I realized it is just not worth going insane over...just live with it or sell your truck and get a TOYOTA.
Yaa, then all you have to worry about is stopping before you go over a cliff or kill someone else. LOL
