88 F250 Steering Column
Old Feb 13, 2010 | 04:23 PM
SHW300's Avatar
SHW300
I have a 88 F250 Diesel. I replaced the ignition switch (not key switch) by lowering the steering column, now the truck will not shift into anything but reverse. I have disconnected the linkage at the transmission & the lock is in the steering column, not the transmission. Thw wheels turn freely, so the bind is somewhere in the shift linkage. What is the problem & what did I do wrong? Thanks
Old Feb 13, 2010 | 05:27 PM
Blue Rebel's Avatar
Blue Rebel
The end of one of the rods probably fell/popped out of its hole. Gonna have to drop the column again and see whats going on.
Old Feb 13, 2010 | 06:05 PM
SHW300's Avatar
SHW300
Please excuse my ignorance. Is there a schematic or diagram of the shift lever in the steering column. I only let the steering column down about six inches. I unbolted the support that holds the steering column up. Many thanks for the help.
Old Feb 13, 2010 | 06:51 PM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
is the reason for replacing the ignition switch because the truck would not start with the key??
i bet so.
if that is the case, your problem was most likely not with the switch, but with the upper actuator. it is a little pot metal piece in the upper column that breaks, preventing the starter from engaging. it will also break in a way that will not let your shifter work.
Old Feb 13, 2010 | 07:04 PM
SHW300's Avatar
SHW300
That was the problem. The rod will not push the ign switch hard enough to engage the starter but it will turn on all electronics. Will I have to remove the steering wheel to fix this problem? What do I need to do next? I installed a push button start button to bypass the start problem.
Is there a way to get to the upper column without removing the steering wheel?
Old Feb 13, 2010 | 07:14 PM
tjc transport
i ain't rite
you will need to remove the wheel and dig a little deeper. the part is only around $13 from the dealer, and takes a few hours to change.
here is a very good breakdown of the actuator replacement
http://fullsizebronco.com/forum/showthread.php?t=70454
Old Feb 13, 2010 | 07:25 PM
SHW300's Avatar
SHW300
That looks like alot of work. It's funny that nothing was wrong with the shifer until I lowered the column. Thanks for the link.
Old Feb 14, 2010 | 07:08 AM
tjc transport
i ain't rite
i have replaced at least 10 actuators so far, and 4-5 columns also. sometimes the column is just plane worn out, and not worth fixing.
T_Cooksey88
Mar 17, 2016 11:23 AM
noddaz
Mar 28, 2011 10:33 AM
iron1951
Feb 18, 2011 06:39 PM
pukey
Dec 31, 2010 04:21 PM
dawfun
Aug 30, 2010 01:08 AM
