removing steering column (shift linkage)
Old Dec 31, 2010 | 04:13 PM
pukey's Avatar
pukey
when removing the steering column on the top part of the shift linkage does that just pull off of the steering column? or do i need to unbolt the shift linkage? On a 86 F-250 non tilt steering column
Old Dec 31, 2010 | 04:21 PM
ri_truck_guy's Avatar
ri_truck_guy
The shift linkage will pry out of the column, but can be a real bear if the bushing is old. I've usually had luck getting them to press out with slip-joint pliers.
1956_F100
Mar 7, 2017 08:49 PM
T_Cooksey88
Mar 17, 2016 11:23 AM
Canus
Dec 12, 2012 10:06 PM
jeff14346
Jan 2, 2012 05:43 AM
iron1951
Feb 18, 2011 06:39 PM
