Steering Column and shift Linkage Question
Old Feb 18, 2011 | 03:21 PM
iron1951's Avatar
iron1951
My truck won't start in park but starts in neutral. I know that here is a park/neutral switch on the transmission. My question is, is there also another park/neutral switch in the steering column? I have been adjusting the shift linkage. I think there is too much slop in the bushings down by the transmission and the frame. Is there a procedure for adjusting the shift linkage? The truck started in park before.
Old Feb 18, 2011 | 04:09 PM
ri_truck_guy's Avatar
ri_truck_guy
The only neutral safety switch is on the transmission. I would disconnect the linkage at the transmission and make sure the transmission is firmly in the park position by hand. Try to start the truck. If it fires, you likely have a linkage problem. If it doesn't fire, it's either the switch itself, the wiring, or possibly the ignition switch itself is worn or out of adjustment. If that's the case we can help walk you through a diagnostic process.
Old Feb 18, 2011 | 06:24 PM
iron1951's Avatar
iron1951
The reason I asked, I disconnected the linkage, hand shifted to neutral and the truck would turn over. Hand shift to park and the truck would not turn over. My wife started to play with the shifter, still disconnected, and the truck would not turn over in neutral. My wife was turning the key. Does the shifter on the column prevent the key from turning to start?
Old Feb 18, 2011 | 06:39 PM
ri_truck_guy
Inside your steering column, there are several pieces that connect your ignition lock to the actual ignition switch which is located on the top of the steering column underneath the dash. In short, there's a gear that connects the back of the lock to a rod that runs down the column to the switch. It runs through the shifter collar. Your issue is more likely in the column itself, not the transmission linkage. Use the search fucntion on the top of the page with the keywords ignition switch and you should easily find several threads with diagrams and directions for checking/repairing the upper column.
DDB1973
Feb 10, 2025 10:31 PM
dasoundman
1978 - 1996 Big Bronco
Jul 14, 2017 05:37 PM
BamBam112686
Jun 22, 2017 12:01 PM
hharris8
208
Feb 15, 2017 10:56 AM
tl1965
Aug 29, 2015 03:45 PM
