2 valve V10
Have any of you pulled this amount of weight with a 2 valve V10? Please share you experiences. I can't afford to buy a new truck and trailer too and now it looks like that is exactly what I'll have to do. I'd appreciate any and all ideas of how I could get my truck to pull 10,000 lbs. Thanks.
JL
It's rather rough when the truck is empty.
I found on the flats I get better mileage by locking out overdrive and running about 60mph.
My Truck scaled empty with full fuel, my wife and I in it & the fiver hitch installed at 6,940. My pin weight loaded was2300lbs.
On the flats here in Illinois I get low 9's to low 10's for miles per gallon. They told me my traile was to heavy for the truck too. But I have been very happy with it.
Hope this helps you. That engine is a work horse.Forgot to add, get a transmission guage. get something that plugs into the OBD port. I have one that is inst in the test port and I have a Scan guage that plugs in there is a 40 to 45 degree diff. My temps are fine as long as I'm not in the mountains. If you are getting much over 240 it might be a good idea to pull over and let it cool. Change fluid if it gets burnt look. I normally change mine every couple years as a precaution. But that is just me, fluid id cheaper than Trans.
Also I had 700lbs to spare before being over on truck GVW, but was no where near over axle ratings.
Forgot to mention mine is a SRW, nota dually
Good Luck : Hope I helped
judgerr
. Your v10 will handle that weight just fine. You can regear the truck to 4.30 or 4.56 cheaper than you can get a new diesel truck. And with those low miles on the truck no need to get ride of it.Call us if you have any other questions.. Be glad to help out..
Mike
I just used a RPM calculator and with the 265 tires and 4.55 gears you would be very close to the rpm I run with 215s and 4.30.
Denny
For F-350 , V10 , 4x4 , Crew cab, Auto Tranny , Single Rear Wheel
3.73 Rear axle rated for max. 10,200 Lbs (maximum loaded trailer ).
4.3 Rear axle rated for max. 13,200 Lbs.
If you significantly go over the max. , most likely the weakest link (the tranny) will give up first. As mentioned by others , your engine is good (rated for max 13,600# of 5'er ) , it is just a matter of having the right rear axle ratio installed .
Good luck and happy trails,
Ken
PS. Also ,consider the hitch weight of your future fifth wheeler . Your max. payload is about 3,500 Lbs ( again according to 2003 Ford brochures I have ) . Your max. hitch should be about 2500 Lbs .
judgerr
Judgerr,
Thank you for all that information. It helps me feel better about my truck. Just two more questions: you say your truck weighs 11,200 pounds, is that loaded and ready to travel or empty? And it sounds like you stay out of overdrive all the time, is that correct?
Thanks,
Greg
I do lock out O/D It pulls O.K. in O/D on the flats. But I found I get better fuel mileage with out it as stated above. I found in O/D I was lugging the engine. In order to get in the power band, I had to run 70mph. I am not comfortable towing this much weight at that speed.
People told me I wouldn't be able to pull this much weight. I was going to change the rear end. But with 4X4 you have to change two, it is expensive! But certainly cheaper than trading trucks. But I would try towing the way it is first then decide. You can change the gearing if you decide you can't live with it the way it is. But I bet if you aren't in a hurry to get up a mountain you will be fine.
Another thing you might checkinto is an auxillary transmission with over /under gearing. I thought about that, but decided I am fine with the truck the way it is.
Good luck
judgerr
Thanks again for your information. I was trying to learn more specifically about your trailer weight. Is it 11,200 dry ie. empty, the way it came from the factory? Or, is it 11,200 all loaded up with your camping supplies and ready to hit the road?
People have told me that when I head out for a several month long trip I could easily load up to 2000 pounds of camping gear, food, clothes etc. So I'm trying to figure out if you are pulling 11,200 down the road or perhaps it is more than that.
Thanks again.
Greg
You don't have to take everything you own. But I had tools, and we had all we needed. We added a little less than 1,000 lbs. I am certain we are heavier than that now. Things get added over time. But it still pulls fine. I really need to weigh it again. I bet we have added at least 500lbs now!
you don't need to haul a lot of groceries etc. some things you can buy when you get there.
You will probably be fine!
judgerr
