2 valve V10
Have any of you pulled this amount of weight with a 2 valve V10? Please share you experiences. I can't afford to buy a new truck and trailer too and now it looks like that is exactly what I'll have to do. I'd appreciate any and all ideas of how I could get my truck to pull 10,000 lbs. Thanks.
Thats almost the exact setup I purchased in 2004, except mine is a 6' box. I towed a TT for a while that weighed 7,200 lbs. It towed ok and could handle going over the Sierra with very little speed lost on the grades.
Then got a 10,000 lb 5th wheel and still had the 3.73 gears, which was fine until I hit a hill, any hill would kill the mph. I changed the gears out to 4.30's and kept the stock size tires and the truck tows like a champ. I also did a couple of other mods. New Voliant CAI, y-pipe and keep the fuel filter changed. I had the truck and 5th weighed once at a truck scale off I-80 and weighed in at 19,700 total, minus me!
The truck tows up 8% grades with little problem and can maintain 55 to 60 mph. If I throw the 4 speed into 2nd gear as I start up a steep hill I can easily accelerate up any hill.
Change the gears, but think about going with 4.56, I'm happy with the 4.30's, but wish I'd gone with the 4.56's or even higher. The milage and higher rpms wasn't even worth concerning myself over after all was said and done.
How much did it cost you to change gears to 4.30? I was quoted 3500.00 from the local ford garage. I don't have enough experience with this to know what is a fair price.
Thanks,
The swap was worth every penny. I do a lot of towing over the Sierra's with the highest pass about 9,000 ft. The 3.73's were fine if I wasn't in any hurry. The 4.30's are much better but I should have gone to the 4.56's if I had to do it over. If your going to spend the money you might as well go with more the rpm change wasn't that much, If I remember the chart I kept the rpms increased 1,200 out of overdrive and 750 in OD.
I have been thinking about it also. Is 750 rpm increase correct? Sounds like alot, but have no idea.
here's the chart I made to keep track of the changes.....
TOWING OVERDRIVE OFF
3.73's ..............................4.30's
50mph 2,000 rpms............50 mph 2,250 rpms
55 mph 2,250 rpms............55 mph 2,500 rpms
60 mph 2,500 rpms............60 mph 2,750 rpms
65 mph 2,750 rpms............65 mph 3,000 rpms
TOWING OVERDRIVE ON
50mph 1,250 rpms...........50 mph 1,500 rpms
55 mph 1,500 rpms...........55 mph 1,750 rpms
60 mph 1,750 rpms...........60 mph 2,000 rpms
65 mph 2,000 rpms...........65 mph 2,250 rpms
NOT TOWING OVERDRIVE ON
50mph 1,125 rpms...........50 mph 1,375 rpms
55 mph 1,3758 rpms.........55 mph 1,625 rpms
60 mph 1,625 rpms...........60 mph 1,875 rpms
65 mph 1,875 rpms...........65 mph 2,125 rpms
Hope this helps in your choice....
Greg
Last edited by wfof250v10; Mar 10, 2010 at 04:31 PM. Reason: change format of chart
Are you running a non stock tune?
The Scangauge II has an Xgauge code to monitor the Converter Speed Ratio (in to out) Never tried using it but it may be able to show when the converter is locked and unlocked.
