Modular V10 (6.8l)
2 valve V10
Old Feb 14, 2010 | 03:00 PM
1ViciousGSX's Avatar
1ViciousGSX
This is my rig, all 20,520 lbs of it and I do fine. Flat interstate driving is fine at 60-65mph, if I get into a lot of ups and downs due to overpasses, I'll just take it out of overdrive. If you have the 4R100 tranny, taking it out or overdrive will give a final drive ratio of 5.32.
Divide 3.73 by .7 which is what the OD ratio is.
So, 3.73 / .7 is 5.32
And that's only if you're running at highway speeds. General all-around acceleration will still be the same
My post about my towing experience.
https://www.ford-trucks.com/forums/8...-on-board.html
Any and all mods are in my sig.
Old Feb 14, 2010 | 04:00 PM
TeamMudd's Avatar
TeamMudd
never mind....... found the right calculator..... it was alittle more involved, buy yes i see what your saying. basicaly you're running the same rpm's in (D) as you would be in (OD) with a gear ratio of about 5.38......2500 rpm's.
if you had a 31" tire with a 5.38 rear end ratio you'd be running at about 2500 rpm's in (OD) at 60mph
with a 31" tire with 3.73's running in (D) your running 2500 rpm's at 60 mph. i'm tracking with ya now........
sorry bout that!
Old Feb 14, 2010 | 04:05 PM
1ViciousGSX
Originally Posted by TeamMudd
on the 4R100 3rd gear (D) is 1.00:1 ratio, OD is .71..... if you're driving in (D) then your at a 1:1 ratio to your rear end. if your running in (D) then your effective ratio to the ground isn't 5.32..... in (OD) at .71:1 with 3.73 gears, your looking at a 2.65:1 final drive, 1:1 (OD) will be a final drive of what ever your rear end is.
Oh yeah, you are correct. I guess my comparison was meant to be between the 5.32 rear end in OD vs. the 3.73 in D.
Old Feb 14, 2010 | 04:10 PM
TeamMudd's Avatar
TeamMudd
HAHA you caught me as i was editing, lol, yea i was tracing with ya once i started calculating.
Old Feb 14, 2010 | 10:11 PM
Pinky Demon's Avatar
Pinky Demon
Here is my advice mods wise:
ScanGauge II
Intake
Headers
Exhaust
Diff. Cooler Cover (Mag Hytec)
High Cap. Tranny Pan w/ Cooler Fins (Mag Hytec)
Re-Gear
5 Star Tune
Old Feb 14, 2010 | 10:45 PM
twayneb's Avatar
twayneb
Late into this but I have a 2000 ext. cab shortbox 4x4 with 4.30 gears that weighs out at 7200 with the V10. I pulled a fiver weighing 13k over mountains with no problems. Truck is not tricked out. I now have a 16k trailer that I hauled to a permanent site in the rockies with no problem and never dropped below 50 mph up an 8 percent grade
Old Feb 16, 2010 | 05:37 PM
larry_kruzan's Avatar
larry_kruzan
Hey Judgerr,
Nice to meet another Illinois tower - I'm hauling a Jayco Eagle 320RLDS.
I didn't quite follow what you are using to monito the tranny temp? Do you have a link to the kit?
I'm towing close to 10k with my SD E-350 also with 3.73 gears. Thinking about regearing it but the van only has 18k miles on it - don't want to mess up warrenty yet <BG>.
Thanks, Larry
Old Feb 17, 2010 | 01:58 AM
judgerr's Avatar
judgerr
This is quite a gadget. Takes awhile to get it honed in for MPG. But worth the effort. As you can see from the site it monitors a lot of things. I love it. It also does trouble codes.
Think Spring!
ScanGaugeII - Scan Tool + Digital Gauges + Trip Computers
Old Feb 17, 2010 | 02:32 AM
larry_kruzan
Ordering it
This is freaking AWESOME! This little gizmo will replace a pile of testing gear and it can just stay inline. I love it.
For the price I'll order two and give one to my son for his birthday - then he'll leave mine alone <BG>
Thanks my Friend,
Larry
Old Feb 17, 2010 | 02:57 AM
judgerr's Avatar
judgerr
It's worth every penny!
Just to be able to monitor your actual coolant and Trans temps. But when you throw in all the other stuffit does, it's a real bargain!
I've had mine three years I think. I got it to where it gives the mileage with in .1 of a mile per gallon of figuring by hand.
The nice thing is you can unplug it and move it to another vihicle.
Happy Towing,
judgerr
By the way you aren't far from me. I live in the country, about five miles north of Utica.
Old Feb 17, 2010 | 08:10 PM
saggys's Avatar
saggys
How does it do transmission temp? I do not see that option listed.
Old Feb 17, 2010 | 08:41 PM
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by klr650goldwing
I'd appreciate any and all ideas of how I could get my truck to pull 10,000 lbs.
All you have to do is hitch it up. Just lock it out of OD and go.
Gears and a tune will make it better but it pulls great stock, even with the 3.73s.
Who told you It could not pull 10K?
Old Feb 17, 2010 | 11:27 PM
  #28
larry_kruzan
Towing power
I'm going for the new trailer on Friday and in one month we are heading to the west coast. Guess I'll find out when I hit the rockies
After we hit big water on the coast I plan to turn left until I see the boarder then trun left again, when we pas New orleans I'll decide to go straight or turn left for Illinois and home.
By the time this run is over I'll know if I need gears.
Larry
Old Feb 17, 2010 | 11:52 PM
  #29
bill11012's Avatar
bill11012
Sounds like a fun trip, you should start a thread and tell us about how the V10 did when you get back.
2 Things I would not go with out
1 a WD hitch.
2 a way to monitor trans temp.
Even with the newer 5R110 I would worry about tranny heat pulling the rockies.
Old Feb 18, 2010 | 04:55 AM
  #30
judgerr's Avatar
judgerr
You have to use the "X-GAUGE" feature!
ScanGaugeII - Add-A-Gauge
Larry
Just don't get in a hurrry in those mountains. When you get over 10,000 ft you will lose a lot of power. But you will get there, just watch that Transmission temp!
And have fun!
judgerr
