Modular V10 (6.8l)
2 valve V10
Old Feb 19, 2010 | 10:42 AM
  #31
saggys's Avatar
saggys
Thanks judgerr
Old Feb 19, 2010 | 10:45 AM
  #32
1ViciousGSX's Avatar
1ViciousGSX
Does the ECU actually monitor the Trans Temp, or does some type of sensor have to be added?
Old Feb 19, 2010 | 10:48 AM
  #33
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Hi 1ViciousGSX
ECU can monitor. Your LW can monitor that PID, just need to set up custom PID using SCT's FREE Livelink software.. You can download it from thier site.
www.sctflash.com
Old Feb 19, 2010 | 10:50 AM
  #34
1ViciousGSX
Originally Posted by fordmdb
Hi 1ViciousGSX
ECM can monitor. Your LW can monitor that PID, just need to set up custom PID using SCT's FREE Livelink software.. You can download it from there site.
www.sctflash.com
Did they ever get that software working with Vista 64bit?
Old Feb 19, 2010 | 12:00 PM
  #35
Johnny Langton's Avatar
Johnny Langton
Originally Posted by bill11012
Even with the newer 5R110 I would worry about tranny heat pulling the rockies.
I wouldn't. The trans cooler is massive compared to what comes with the 4R100,and the PCM's trans strategy is much better.
JL
Old Feb 19, 2010 | 12:06 PM
  #36
Skattracker3's Avatar
Skattracker3
In response to the original post on this thread.
I pull a 9000-9500 lbs 5th wheel camper with my 2002 F350 4x4, at, 3.73 gears with a 2 valve V10. I also will pull my boat behind it at times. I live in Minnesota, so pretty flat. Truck does great around here. When I get out into the Dakota's and start pulling larger hills on the freeway, it will struggle to maintain 70 mph unless you really get into it, but does pretty well.
I have towed my camper into Yellowstone by way of Beartooth pass (6-10% grades for 20 miles) and have pulled it up US 14A through the Big Horn Mountains of Wyoming (8-12% grades with a few 14% spots for 17 miles). It does OK in the mountains, but you do run out of power around 10,000 ft. Both of the passes I have mentioned are not recomended for campers, but it does it pretty well. Where you will see your issue, (if it is) is you will not be the fastest one up the passes, but it will do it. You may get passed by a diesel pulling the same size camper, but they are probably not stock either.
Hope it helps.
Old Feb 20, 2010 | 05:57 PM
  #37
lariat79sc's Avatar
lariat79sc
Most people with 3.73 V10's have to feel frustrated towing much past #5000. I know I do. I absolutely hate those gears. Someday when I finish college and have money again I'm installing 4.30's. It is too much a disappointment "as is", when the ball hitch comes out...
Old Feb 20, 2010 | 06:21 PM
  #38
1ViciousGSX
It doesn't really bother me. Takes a little while to get up to speed, but once I'm there and OD is off, everything is good.
Old Feb 20, 2010 | 07:22 PM
  #39
5 Star Tuning
Former Vendor
Livelink 6
<TABLE cellSpacing=3 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=top align=left width="74%">Live Link Data Logging Software</TD><TD vAlign=top align=left width="26%" rowSpan=8><TABLE cellSpacing=3 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=center align=middle></TD></TR><TR><TD vAlign=center align=middle></TD></TR></TBODY></TABLE></TD></TR><TR><TD vAlign=top align=left>Application: X3 / SF3 / TSX Flash Devices</TD></TR><TR><TD vAlign=top align=left>Current Version:6.1</TD></TR><TR><TD vAlign=top align=left>Last Updated:01-19-2010</TD></TR><TR><TD vAlign=top align=left>Description:</TD></TR><TR><TD vAlign=top align=left>Live Link Datalogging Software</TD></TR><TR><TD vAlign=top align=left>Notes:</TD></TR><TR><TD vAlign=top align=left>This version is compatible with XP/Vista/Windows 7 computers both 32bit and 64bit.
SCT Automotive Performance Products
Old Feb 20, 2010 | 07:32 PM
  #40
Skattracker3
Everyone talks gears. Is there a big difference as to towing around 10,000 lbs?
I have 3.73, have thought about going to 4.30, but at what cost?
If I could buy axles I could do it myself, but I don't think I want to tackle a gear swap.
Has anyone had there gears changed from 3.73 to ? and what cost and how do they like them?
Thanks
Old Feb 20, 2010 | 07:46 PM
  #41
1ViciousGSX
My 5th-wheel weighs a little over 13K (20.5K as a complete rig w/truck) and I tow it fine with 3.37 gears. I just take it out of OD when going over small hills and overpasses. And 5-Star's tow tune kick out of OD early if I'm driving anywhere under 60 mph, but it keeps the converter locked which helps keep the trans temps down. BUT, if you plan on going over mountains a lot, 4.30 gears would be better.
Old Feb 20, 2010 | 07:54 PM
  #42
Skattracker3
I have pulled lots of passes, does OK, just wondering if there is a huge difference with 4.30.
My 5 star arrives on Tuesday, we will see what difference there is.
Old Feb 20, 2010 | 08:01 PM
  #43
1ViciousGSX
Well I can there will definitely be a difference, but a cost of fuel economy.
Old Feb 20, 2010 | 08:05 PM
  #44
Skattracker3
Have you experienced a loss in MPG with the 5 star?
Old Feb 20, 2010 | 08:23 PM
  #45
bill11012's Avatar
bill11012
Modular motor junkie
I do not think he has, He was talking about the gearing question.
